C++ cannot write simple text file
Sysprogs forums Forums VisualGDB C++ cannot write simple text file
  • #7608
    jburrus
    The following C++ test code should write a simple txt file in a specified folder in a remote server under CentOS:
    #include <fstream>
    #include <string>
    int main(int argc, char* argv[])
     std::string content = "This is a test content.";
     std::string filename = "/myFolder/myFile.txt";
     std::ofstream file;
     file.open(filename.c_str());
     file << content;
     file.close();
    return 0;
    It compiles and works properly in gcc 5.3.1. While it does compile using VisualGDB, it surprisingly does not write actually the file.
    The following post in stackoverflow (http://stackoverflow.com/questions/16779149/c-program-in-xcode-not-outputting-simple-text-file-using-outfile) seems to mention a similar issue in Xcode. It suggests this is merely a setting in VisualGDB.
    How to set up VisualGDB in order to fix this problem?
    Thank you for your time.
    Jacques Burrus
    #7612
    Most likely either your user account does not have access to the directory where you are trying to create the file, or you are running it on a wrong machine. Please try to change the directory of the file to /tmp and if it does not help, try running the executable directly over SSH.
    #7615
    jburrus
    Hi Bazis.
    Thank you for your reply. The mistake was indeed the access and changing the corresponding settings solved the problem.
    Regards,
    Jacques Burrus
    #7629
    No problem. If you encounter further problems, feel free to create a new thread.
