C/C++ mix intellisense broken
Sysprogs forums › Forums › VisualGDB › C/C++ mix intellisense broken
  • #28078
    isigor
    I’m working on project which mixes C/C++ files
    I have noticed that intellisense is broken in the following way:
    having “main.c” to be compiled as C++ which includes “header.h”
    “header.h” are driver libs from manufacturer which contains extern “C” to support C and C++ compilation
    this compiles with no errors, but  intellisense is not recognized extern “C” that way, it errors “[Clang InteliSense] Error: expected identifier or ‘C’
    which means this header file recognized as C++ header file but InteliSense doesn’t think that.
    Inside this header there is a simple function called XXX which not recognized by InteliSense in main.c [Clang InteliSense] Warning: implicit declartion of function ‘XXX’ is invalid in C99
    If I set “main.c” as C it solves InteliSense recognition problem but it won’t compile, because main.c also includes other C++ header which contain classes, therefore it needed to be compiled as C++.
    I have attached simple project which describes the problem
    I hope you could help me solve with this issue, working InteliSense with C/C++ mix is a must for me
    Best regards
    Igor
    #28079
    isigor
    #28089
    No problem, we have updated VisualGDB’s IntelliSense engine to properly handle the “-x c++” flag for .c file in MSBuild projects. Please try this build: VisualGDB-5.5.5.3602.msi
    Please make sure you delete the CodeDB folder before you open the solution, as it would contain cached settings from the previous version.
    #28093
    isigor
    Thanks for quick response
    Is works now 🙂
