Sysprogs forums › Forums › VisualGDB › Builds runs on one Pi 4 and not two others.
- This topic has 5 replies, 2 voices, and was last updated 5 years, 5 months ago by
October 30, 2020 at 17:44 #29420
richardf
ParticipantI have reported this issue a while ago.
I have three identical Pi 4. I am running Visual Studio Community 2019 and VisualGDB 5.5R2 (although this happened before). I can build and run on pi$bblack yet can’t build on pi$ablack (although it did build a few months ago).
As I recall, back then, I rebuilt the project from scratch and it worked, yet the problem is back.
Same code. See file.
Help.
You must be logged in to view attached files.November 1, 2020 at 10:16 #29424support
It looks like the target board is missing the ninja tool that is used to check dependencies and rebuild out-of-date files without any extra network delays. You can install ninja by running “sudo apt install ninja” on Raspberry Pi, or by creating another MSBuild-based project targeting that device from scratch, so that VisualGDB could recheck and install the required tools.
November 3, 2020 at 08:43 #29436richardf
Participantrm -rf “/tmp/VisualGDB/c/RaspGlo/GloR/VisualGDB/Debug”
C:\RaspGlo\GloR => /tmp/VisualGDB/c/RaspGlo/GloR: 147 files copied (686KB).
ninja -f “VisualGDB/Debug/GloR.msbuild-ninja”
bash: ninja: command not found
Command exited with code 127
Executable: ninja
Arguments: -f “VisualGDB/Debug/GloR.msbuild-ninja”
Directory: /tmp/VisualGDB/c/RaspGlo/GloR
Command-line action failed========== Project Rebuild Summary ==========
GloR rebuilt in 00:00
========== Rebuild: 0 Succeeded, 1 Failed, 0 Skipped ==========I performed sudo apt install ninja. I rebooted. I am logged in as pi.
If I type ninja I get
pi@ablack:~ $ ninja
log: warning: no configuration file specified, using default values
log: ninja version 0.1.3 initializing
die: error: must run as rootI can build and run successfully using GNU make except it is painfully slow.
thanks
November 3, 2020 at 08:57 #29437richardf
ParticipantI then built an ap from start. When I try to build, I get:
rm -rf “/tmp/VisualGDB/c/RaspberryPi/RaspAps/LinuxProject1/VisualGDB/Debug”
C:\RaspberryPi\RaspAps\LinuxProject1 => /tmp/VisualGDB/c/RaspberryPi/RaspAps/LinuxProject1: 1 files copied (253 bytes).
ninja -f “VisualGDB/Debug/LinuxProject1.msbuild-ninja”
Executable: ninja
Arguments: -f “VisualGDB/Debug/LinuxProject1.msbuild-ninja”
Directory: /tmp/VisualGDB/c/RaspberryPi/RaspAps/LinuxProject1
LinuxProject1 rebuilt in 00:02
========== Rebuild: 0 Succeeded, 1 Failed, 0 Skipped ==========November 5, 2020 at 08:10 #29445richardf
ParticipantI build a simple ap from start. When I try to build on one of my Raspberry pi’s, I get:
Executable: ninja
Command-line action failedNovember 5, 2020 at 08:35 #29447 -
