Sysprogs forums › Forums › VisualGDB › Building Arduino for nrf52840 Feather Express
- This topic has 2 replies, 2 voices, and was last updated 5 years, 6 months ago by
occamman.
September 10, 2020 at 19:54 #29010
occamman
ParticipantI’d like to develop using Arduino on the nrf52840 Feather Express. I created a new project using the wizard, that all seemed to go well. But when I try to build blinky, things become unhappy. Please see attached screen snaps. The entire log that is displayed is below. Any pointers wold be deeply appreciated!
VisualGDB version: 5.5.4.3540
(gdb begin)
— GDB Session —
VisualGDB is licensed to Alan Cohen
-gdb-version
C:\Users\amc79\AppData\Local\Arduino15\packages\adafruit\tools\arm-none-eabi-gcc\9-2019q4\bin\arm-none-eabi-gdb.exe: warning: Couldn’t determine a path for the index cache directory.
=thread-group-added,id=”i1″
~”GNU gdb (GNU Tools for Arm Embedded Processors 9-2019-q4-major) 8.3.0.20190709-git\n”
~”Copyright (C) 2019 Free Software Foundation, Inc.\n”
~”License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>\nThis is free software: you are free to change and redistribute it.\nThere is NO WARRANTY, to the extent permitted by law.”
~”\nType \”show copying\” and \”show warranty\” for details.\n”
~”This GDB was configured as \”–host=i686-w64-mingw32 –target=arm-none-eabi\”.\n”
~”Type \”show configuration\” for configuration details.\n”
~”For bug reporting instructions, please see:\n”
~”Find the GDB manual and other documentation resources online at:\n <http://www.gnu.org/software/gdb/documentation/>.”
~”\n\n”
~”For help, type \”help\”.\n”
~”Reading symbols from C:/Users/amc79/source/repos/nrf5240_Feather_Test1/Output/Adafruit_Feather_nRF52840_Express/Debug/nrf5240_Feather_Test1.ino.elf…\n”
~”\n\n”
^done
-list-features
^done,features=[“frozen-varobjs”,”pending-breakpoints”,”thread-info”,”data-read-memory-bytes”,”breakpoint-notifications”,”ada-task-info”,”language-option”,”info-gdb-mi-command”,”undefined-command-error-code”,”exec-run-start-option”,”data-disassemble-a-option”]
-gdb-set verbose on
^done
-gdb-set print demangle off
^done
target sim
&”target sim\n”
&”Undefined target command: \”sim\”. Try \”help target\”.\n”
^error,msg=”Undefined target command: \”sim\”. Try \”help target\”.”
load
&”load\n”
&”You can’t do that when your target is `exec’\n”
^error,msg=”You can’t do that when your target is `exec'”
info target
&”info target\n”
~”Symbols from \”C:\\Users\\amc79\\source\\repos\\nrf5240_Feather_Test1\\Output\\Adafruit_Feather_nRF52840_Express\\Debug\\nrf5240_Feather_Test1.ino.elf\”.\n”
~”Local exec file:\n”
~”\t`C:\\Users\\amc79\\source\\repos\\nrf5240_Feather_Test1\\Output\\Adafruit_Feather_nRF52840_Express\\Debug\\nrf5240_Feather_Test1.ino.elf’, file type elf32-littlearm.\n”
~”\tEntry point: 0x26318\n”
~”\t0x00026000 – 0x0002ef74 @ 0x00006000 is .text\n”
~”\t0x0002ef74 – 0x0002ef7c @ 0x0000ef74 is .ARM.exidx\n”
~”\t0x20006000 – 0x20006240 @ 0x00016000 is .data\n”
~”\t0x20006240 – 0x20007a64 @ 0x00016240 is .bss\n”
~”\t0x20007a64 – 0x2003f800 @ 0x00016240 is .heap\n”
^done
-data-evaluate-expression “&_estack”
^error,msg=”No symbol \”_estack\” in current context.”
-data-evaluate-expression “&__StackLimit”
^done,value=”0x2003f800″
-data-evaluate-expression “sizeof(void *)”
^done,value=”4″
-data-evaluate-expression “sizeof(int)”
^done,value=”4″
-data-evaluate-expression “sizeof(short)”
^done,value=”2″
-data-evaluate-expression “sizeof(long)”
^done,value=”4″
-data-evaluate-expression “sizeof(long long)”
^done,value=”8″
-data-evaluate-expression “sizeof(char)”
^done,value=”1″
-data-evaluate-expression “sizeof(wchar_t)”
^done,value=”4″
-data-evaluate-expression “sizeof(float)”
^done,value=”4″
-data-evaluate-expression “sizeof(double)”
^done,value=”8″
-data-evaluate-expression “sizeof(long double)”
^done,value=”8″
-var-create – * “*((void **)0x2003f7fc)”
^done,name=”var1″,numchild=”0″,value=”0x0″,type=”void *”,has_more=”0″
-var-assign “var1″ 0x4e0294bd
^error,msg=”-var-assign: Could not assign expression to variable object”
-break-insert -f main
^done,bkpt={number=”1″,type=”breakpoint”,disp=”keep”,enabled=”y”,addr=”0x00027aec”,func=”main()”,file=”C:\\Users\\amc79\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\nrf52\\0.20.5\\cores\\nRF5\\main.cpp”,fullname=”C:\\Users\\amc79\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\nrf52\\0.20.5\\cores\\nRF5\\main.cpp”,line=”72″,thread-groups=[“i1″],times=”0″,original-location=”main”}
-exec-run
^error,msg=”Don’t know how to run. Try \”help target\”.”Attachments:
You must be logged in to view attached files.September 11, 2020 at 16:55 #29024support
Looks like you are trying to use the GDB simulator that does not support your device. Generally, the built-in simulator is not usable for ARM targets and can only be used to verify that gdb is able to load the debugging symbols.
Please consider using one of the supported debug methods instead.
September 12, 2020 at 06:02 #29027occamman
ParticipantBingo, working fine with my J-Link. Thank you for an excellent product with support to match.
