Sysprogs forums › Forums › VisualGDB › Build problems with Cube Tutorial
- This topic has 4 replies, 3 voices, and was last updated 9 years ago by
December 18, 2016 at 20:04 #9819
RolfSt
I’m getting the following build problem:
Warning overriding recipe for target `Debug/system_stm32f4xx.o’ CubeDemo C:\projects\CubeDemo\CubeDemo\Makefile 473
Warning ignoring old recipe for target `Debug/system_stm32f4xx.o’ CubeDemo C:\projects\CubeDemo\CubeDemo\Makefile 185
Error ld returned 1 exit status CubeDemo C:\projects\CubeDemo\CubeDemo\collect2.exe 1
Error Command-line action failed CubeDemo C:\projects\CubeDemo\CubeDemo\VisualGDB 1
Error Build has failed. See the Output window for more details. CubeDemo C:\projects\CubeDemo\CubeDemo\EXEC 1
Error MSB3073 The command “”C:\Program Files (x86)\Sysprogs\VisualGDB\\VisualGDB.exe” /build “C:\projects\CubeDemo\CubeDemo\CubeDemo.vcxproj” “/solution:C:\projects\CubeDemo\CubeDemo.sln” “/config:Debug” “/platform:Win32″” exited with code 1. CubeDemo C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V140\Microsoft.MakeFile.Targets 41The only difference to the tutorial is, that I selected my Nucleo STM32F446RET6 as target. I’m using VS community 2015 with update 3.
This error occurs in step 16 of tutorial.
December 19, 2016 at 05:04 #9821support
Please check the Output window of Visual Studio for details on the error. It should explain why the link fails.
December 19, 2016 at 06:52 #9823HorizonBreak
ParticipantHey there.
Had the same problem. Look at your output window for the build. Mine was failing due to multiple definitions of SystemClockUpdate, a result of including STM32F1xx_hal.c (or something like it) twice. I removed the one that STM32CubeMX generated, retaining the version that was included with the HAL package, and my build worked.
Find the function that has multiple definitions, and remove one of the sources of that definition, preferably from the included CubeMX sources. Good luck!
December 19, 2016 at 13:16 #9826RolfSt
ParticipantThanx a lot for quick response,
@HorizonBreak: the same cause, I had only to remove – in my case – system_stm32f4xx.c and tutorial worked as described.December 20, 2016 at 01:37 #9838support
Good to know it works. BTW, VisualGDB should normally recognize and display the ‘multiple definition’ errors properly. If you believe this does not happen and those errors are only visible in the Output window, please feel free to post the Output window contents here and we will update our message parser to display them properly.
