Sysprogs forums › Forums › VisualGDB › Build Error after Uodate
- This topic has 4 replies, 2 voices, and was last updated 4 years, 8 months ago by
January 28, 2022 at 10:25 #32118
meldano
I updated Visual GDB and BSD from an old 2020 Visual GDB to actual Version.
I got following build error
C:\Users\xxx\AppData\Local\Temp\ccMH3DTk.s: Assembler messages:
C:\Users\melne\AppData\Local\Temp\ccMH3DTk.s:253: Error: garbage following instruction — `tst lr,#4 n ite eq n mrseq r0,msp n mrsne r0,psp n ldr r1,[r0,#24] n ldr r2,handler2_address_const n bx r2 n handler2_address_const:.word prvGetRegistersFromStack n’
Failed to compile main.c. arm-none-eabi-gcc.exe exited with code 1The File does not exist and when I click the message, I got a error message box
I clean/rebuidl with no solution.
Can anybody help me?
Daniel
January 28, 2022 at 10:28 #32120January 28, 2022 at 10:35 #32123support
Another common cause of errors is updating to a new toolchain/BSP/SDK. Many of these components are maintained by device vendors or communities, and require minor adjustments to the project when switching to newer versions. If you have recently updated any of such components, please consider reverting back to the old version as described here. There is no need to downgrade VisualGDB itself, as it is updated separately from such components.
January 28, 2022 at 11:27 #32124meldano
ParticipantIt seems the problem is not the new BSP. I use git and reverted all changes, install the old bsp.
Compiling a new project is possible without failure.
January 28, 2022 at 13:37 #32125support
KeymasterIf the problem only happens with a specific project, but not with a similar project created from scratch, it is likely caused by invalid/incompatible values in some of the original project’s settings.
The best way to find out the setting causing the problem is to compare the projects side-by-side (e.g. using KDiff3 or any other diffing tool) and try merging them step-by-step. E.g. if the diffing tool shows differences in .vcxproj, and .vgdbsettings files, you can try replacing just the .vgdbsettings file vs. just the .vcxproj file, to see which of them is causing the issue.
Once you narrow down a specific file, you can use the diffing tool to review the differences within a specific file, and merge them one half at a time, quickly pinpointing a specific setting.
We advise making multiple backups of both projects throughout the troubleshooting, as it is very easy to inadvertently break the project further by changing a slightly different setting.
If a specific setting is not working as expected (i.e. changing it on a freshly created project causes unexpected behavior), feel free to let us know and we will investigate it further.
We can also gladly do the troubleshooting for you at our consulting rate – it typically takes between 30 minutes and 1 hour to find the root cause of most similar problems. However, as this troubleshooting needs to be done for each project separately and cannot be automated, we have to charge our consulting rate to do that. Feel free to contact our sales for more information.
