I have an enum value embedded in a bit-field defined structure:
enum fix_type_t : uint8_t
no_fix = 0,
kf_solution_1_sv = 0b001,
kf_solution_2_sv = 0b010,
kf_solution_3_sv = 0b011,
kf_solution_4_or_mode_sv = 0b100,
least_squares_solution_2_d = 0b101,
least_squares_solution_3_d = 0b110,
dr_solution = 0b111,
struct __attribute__((packed))
fix_type_t fix_type : 3;
bool tricke_power : 1;
altitude_hold_t altitude_hold : 2;
bool dop_limits_exceeded : 1;
bool dgps_correction_applied : 1;
bool sensor_dr : 1;
bool navigation_overdetermined : 1;
bool velocity_dr_timeout : 1;
bool reserved : 1;
bool invalid_velocity : 1;
bool altitude_hold_diabled : 1;
dr_error_t dr_error : 2;
Compilation is ok (I get a warning about type being too small to contain all values, but that’s fine), I can check the result is ok (I know the expected value, so I placed an “if(value == expected_value) then __nop()” and the nop is getting called. So function wise all is perfect.
But when debugging, if I try to check the enum value at runtime with the debugger, I get a value “-4” instead of kf_solution_4_or_mode_sv. This seems to be a visualization bug.
Thomas.
