Very strange behavior. When we create a project and run it in debug mode for the first time, everything is fine, it starts, but the second time already gives an error:
Run "C:\SysGCC\raspberry64\bin\make.exe CONFIG=Debug" in directory "C:\VS\BSH\LinuxProject1" on local computer
make: *** No rule to make target c\:\sysgcc\raspberry64\aarch64-linux-gnu\sysroot\usr\include/stdc-predef.h', needed byDebug/LinuxProject1.o'. Stop.
Command exited with code 2
Executable: C:\SysGCC\raspberry64\bin\make.exe
Arguments: CONFIG=Debug
Directory: C:\VS\BSH\LinuxProject1
Command-line action failed
========== Project Build Summary ==========
LinuxProject1 built in 00:01
========== Build: 0 Succeeded, 1 Failed, 0 Skipped ==========
If you do clean, it will start again once in debug mode and then not anymore!
This topic was modified 3 years ago by
support. Reason: formatting
