Sysprogs forums › Forums › VisualGDB › breakpoints aren’t hit – No symbol "disassembly" in current
- This topic has 3 replies, 2 voices, and was last updated 11 years, 11 months ago by
hcroyl.
February 27, 2014 at 10:07 #717
hcroyl
ParticipantHello, Just bought a license but I am not able to debug my code, i am getting:
“No symbol “disassembly” in current context.”My break point is in the quakeprogressive.cpp file.
The application runs, but break points are not hit.
What is the problem?(attaching info shared , info sources, output build)
Info Shared command produces:
info shared
&”info sharedn”
From To Syms Read Shared Object Library
0x40053a40 0x4005e5fc Yes C:/Users/royl/AppData/Local/VisualGDB/AndroidBinaryCache/2157b471/linker
0x40087b40 0x400b70c4 Yes C:/Users/royl/AppData/Local/VisualGDB/AndroidBinaryCache/2157b471/libc.so
No libstdc++.so
No libm.so
No liblog.so
No libcutils.so
No libgccdemangle.so
No libcorkscrew.so
No libz.so
No libutils.so
No libbinder.so
No libemoji.so
No libjpeg.so
No libexpat.so
No libstlport.so
No libGLES_trace.so
No libEGL.so
No libGLESv2.so
No libquramimagecodec.so
No libsamsungeffect.so
No libskia.so
No libandroidfw.so
No libnativehelper.so
No libnetutils.so
No libhardware.so
No libsync.so
No libui.so
No libremotedesktop_client.so
No libgui.so
No libcamera_metadata.so
No libcamera_client.so
No libcrypto.so
No libgabi++.so
No libicuuc.so
No libicui18n.so
No libsqlite.so
No libqc-opt.so
No libselinux.so
No libsecure_storage.so
No libdvm.so
No libGLESv1_CM.so
No libETC1.so
No libwpa_client.so
No libhardware_legacy.so
No libomafldrm.so
No libsonivox.so
No libssl.so
No libstagefright_foundation.so
No libspeexresampler.so
No libaudioutils.so
No libsecnativefeature.so
No lib_SamsungVAD_v01005.so
No libsamsungvad.so
No libmedia.so
No libusbhost.so
No libharfbuzz_ng.so
No libLLVM.so
No libbcinfo.so
No libbcc.so
No libRS.so
No libRScpp.so
No libhwui.so
No libandroid_runtime.so
No libbaimobile_platform_sam.so
No libbaimobile_pcsclite_client_sam.so
No libbaimobile_pkcs11_sam.so
No libbaimobile_engine_sam.so
No libsslengine.so
No libjavacore.so
No librs_jni.so
No libdrmframework.so
No libdrmframework_jni.so
No libstagefright_omx.so
No libstagefright_yuv.so
No libvorbisidec.so
No libQSEEComAPI.so
No libhdcp2.so
No libstagefright_enc_common.so
No libstagefright_avc_common.so
No libsavscmn.so
No libsavsff.so
No libstagefright.so
No libmtp.so
No libexif.so
No libstagefright_amrnb_common.so
No libmedia_jni.so
No libexif_jni.so
No libandroid.so
No libchromium_net.so
No libharfbuzz.so
No libv8.so
No libwebcore.so
No libsoundpool.so
No libcommon_time_client.so
No libnbaio.so
No libeffects.so
No libpowermanager.so
No libedmnativehelper.so
No libcontrolcsc.so
No lib_Samsung_Resampler.so
No lib_SoundAlive_SRC192_ver204.so
No lib_soundaliveresampler.so
No libaudioflinger.so
No libvideoeditor_osal.so
No libvideoeditor_videofilters.so
No libvideoeditorplayer.so
No libvideoeditor_core.so
No libvideoeditor_jni.so
0x7501e7f8 0x750da664 Yes C:/svn/trunk/Android/QuakeProgressive/obj/local/armeabi/libquakeprogressive.so
No libPowerStretch.so
No libgsl.so
No libadreno_utils.so
No libEGL_adreno.so
No libGLESv1_CM_adreno.so
No libGLESv2_adreno.so
No eglsubAndroid.so
No libq3dtools_adreno.so
No libsc-a3xx.so
No libmm-abl-oem.so
No libmm-abl.so
No libqdutils.so
No libmemalloc.so
No gralloc.msm8974.so
OKInfo sources Produces
info sources
&”info sourcesn”
Source files for which symbols have been read in:
C:/svn/trunk/Android/QuakeProgressive/jni/quakeprogressive.cpp, C:/svn/trunk/HappyCloudService/Include/LoggingSystem.h, C:/svn/trunk/HappyCloudService/Include/FileUtils.h, C:/svn/trunk/HappyCloudService/Include/log.h, C:/svn/trunk/HappyCloudService/poco-1.4.1p1/Foundation/include/Poco/Bugcheck.h, C:/dev/android-ndk-r9c/sources/cxx-stl/gnu-libstdc++/4.6/include/ext/numeric_traits.h, C:/dev/android-ndk-r9c/platforms/android-17/arch-arm/usr/include/ctype.h, C:/dev/android-ndk-r9c/platforms/android-17/arch-arm/usr/include/locale.h, C:/dev/android-ndk-r9c/sources/cxx-stl/gnu-libstdc++/4.6/include/bits/char_traits.h, C:/dev/android-ndk-r9c/sources/cxx-stl/gnu-libstdc++/4.6/include/ext/new_allocator.h, C:/dev/android-ndk-r9c/sources/cxx-stl/gnu-libstdc++/4.6/include/exception, C:/dev/android-ndk-r9c/sources/cxx-stl/gnu-libstdc++/4.6/include/bits/allocator.h, C:/dev/android-ndk-r9c/sources/cxx-stl/gnu-libstdc++/4.6/include/bits/stl_pair.h, C:/dev/android-ndk-r9c/sources/cxx-stl/gnu-libstdc++/4.6/include/iosfwd, C:/dev/android-ndk-r9c/sources/cxx-stl/gnu-libstdc++/4.6/include/bits/stl_list.h, C:/dev/android-ndk-r9c/sources/cxx-stl/gnu-libstdc++/4.6/include/debug/debug.h, C:/dev/android-ndk-r9c/sources/cxx-stl/gnu-libstdc++/4.6/include/cwctype, C:/dev/android-ndk-r9c/sources/cxx-stl/gnu-libstdc++/4.6/include/cctype, C:/dev/android-ndk-r9c/sources/cxx-stl/gnu-libstdc++/4.6/include/clocale, C:/dev/android-ndk-r9c/sources/cxx-stl/gnu-libstdc++/4.6/include/cstdint, C:/dev/android-ndk-r9c/sources/cxx-stl/gnu-libstdc++/4.6/libs/armeabi/include/bits/c++config.h, C:/dev/android-ndk-r9c/sources/cxx-stl/gnu-libstdc++/4.6/include/bits/exception_ptr.h, C:/dev/android-ndk-r9c/sources/cxx-stl/gnu-libstdc++/4.6/include/cwchar, C:/dev/android-ndk-r9c/platforms/android-17/arch-arm/usr/include/wchar.h, C:/dev/android-ndk-r9c/platforms/android-17/arch-arm/usr/include/time.h, C:/dev/android-ndk-r9c/platforms/android-17/arch-arm/usr/include/stdio.h, C:/dev/android-ndk-r9c/platforms/android-17/arch-arm/usr/include/sys/types.h, C:/dev/android-ndk-r9c/platforms/android-17/arch-arm/usr/include/asm/posix_types.h, C:/dev/android-ndk-r9c/platforms/android-17/arch-arm/usr/include/stdint.h, C:/dev/android-ndk-r9c/platforms/android-17/arch-arm/usr/include/machine/_types.h, C:/dev/android-ndk-r9c/toolchains/arm-linux-androideabi-4.6/prebuilt/windows-x86_64/lib/gcc/arm-linux-androideabi/4.6/include/stddef.h,, C:/dev/android-ndk-r9c/toolchains/arm-linux-androideabi-4.6/prebuilt/windows-x86_64/lib/gcc/arm-linux-androideabi/4.6/include/stdarg.h, C:/dev/android-ndk-r9c/platforms/android-17/arch-arm/usr/include/jni.h
Source files for which symbols will be read in on demand:
/s/ndk-toolchain/src/build/../gcc/gcc-4.6/libgcc/../gcc/libgcc2.c, /s/ndk-toolchain/src/build/../gcc/gcc-4.6/libgcc/../gcc/config/arm/ieee754-df.S, /s/ndk-andrewhsieh/build/toolchain/host-x86_64-linux-gnu/gcc-4.6/./gcc/include/unwind.h, /s/ndk-toolchain/src/build/../gcc/gcc-4.6/libgcc/../gcc/unwind-pe.h, /s/ndk-toolchain/src/build/../gcc/gcc-4.6/libgcc/../gcc/unwind-c.c, /s/ndk-toolchain/src/build/../gcc/gcc-4.6/libgcc/../gcc/config/arm/pr-support.c, /s/ndk-toolchain/src/build/../gcc/gcc-4.6/libgcc/../gcc/config/arm/libunwind.S, /s/ndk-toolchain/src/build/../gcc/gcc-4.6/libgcc/../gcc/config/arm/unwind-arm.c, /s/ndk-toolchain/src/build/../gcc/gcc-4.6/libgcc/../gcc/config/arm/linux-atomic.c, /s/ndk-toolchain/src/build/../gcc/gcc-4.6/libgcc/../gcc/config/arm/bpabi.c, /s/ndk-toolchain/src/build/../gcc/gcc-4.6/libgcc/../gcc/config/arm/lib1funcs.asm, /s/ndk-toolchain/src/build/../gcc/gcc-4.6/libgcc/../gcc/config/arm/bpabi.S, /s/ndk-toolchain/src/build/../gcc/gcc-4.6/libgcc/../gcc/config/arm/ieee754-sf.S, C:/dev/android-ndk-r9c/sources/cxx-stl/gnu-libstdc++/4.6/include/ext/new_allocator.h, C:/dev/android-ndk-r9c/sources/cxx-stl/gnu-libstdc++/4.6/include/bits/move.h, C:/dev/android-ndk-r9c/sources/cxx-stl/gnu-libstdc++/4.6/include/bits/stl_function.h, C:/dev/android-ndk-r9c/sources/cxx-stl/gnu-libstdc++/4.6/include/bits/allocator.h, C:/dev/android-ndk-r9c/sources/cxx-stl/gnu-libstdc++/4.6/include/bits/basic_string.h, C:/dev/android-ndk-r9c/sources/cxx-stl/gnu-libstdc++/4.6/include/bits/basic_string.tcc, C:/dev/android-ndk-r9c/sources/cxx-stl/gnu-libstdc++/4.6/include/bits/stl_pair.h, C:/dev/android-ndk-r9c/sources/cxx-stl/gnu-libstdc++/4.6/include/bits/stl_tree.h, C:/dev/android-ndk-r9c/sources/cxx-stl/gnu-libstdc++/4.6/include/bits/stl_map.h, C:/svn/trunk/HappyCloudService/Include/HCPaths.h, C:/svn/trunk/HappyCloudService/poco-1.4.1p1/Foundation/include/Poco/Exception.h, C:/dev/android-ndk-r9c/sources/cxx-stl/gnu-libstdc++/4.6/include/bits/char_traits.h, C:/dev/android-ndk-r9c/sources/cxx-stl/gnu-libstdc++/4.6/include/new, C:/svn/trunk/HappyCloudService/Include/HCPathsAndroid.cpp, C:/dev/android-ndk-r9c/sources/cxx-stl/gnu-libstdc++/4.6/include/iostream, C:/dev/android-ndk-r9c/sources/cxx-stl/gnu-libstdc++/4.6/include/bits/stl_iterator_base_types.h, C:/dev/android-ndk-r9c/sources/cxx-stl/gnu-libstdc++/4.6/include/bits/stl_construct.h, C:/dev/android-ndk-r9c/sources/cxx-stl/gnu-libstdc++/4.6/include/bits/stl_algobase.h, C:/dev/android-ndk-r9c/sources/cxx-stl/gnu-libstdc++/4.6/include/bits/stl_iterator.h, C:/dev/android-ndk-r9c/sources/cxx-stl/gnu-libstdc++/4.6/include/bits/stl_vector.h, C:/svn/trunk/HappyCloudService/poco-1.4.1p1/Foundation/include/Poco/AutoPtr.h, C:/svn/trunk/HappyCloudService/poco-1.4.1p1/Foundation/include/Poco/ScopedLock.h, C:/dev/android-ndk-r9c/sources/cxx-stl/gnu-libstdc++/4.6/include/bits/stl_set.h, C:/dev/android-ndk-r9c/sources/cxx-stl/gnu-libstdc++/4.6/include/iomanip, C:/svn/trunk/HappyCloudService/Include/ConfUtilsUnix.cpp, C:/svn/trunk/HappyCloudService/poco-1.4.1p1/Foundation/include/Poco/RefCountedObject.h, C:/svn/trunk/HappyCloudService/poco-1.4.1p1/Foundation/include/Poco/AtomicCounter.h, C:/svn/trunk/HappyCloudService/poco-1.4.1p1/Foundation/include/Poco/Mutex.h, C:/svn/trunk/HappyCloudService/poco-1.4.1p1/Foundation/include/Poco/Mutex_POSIX.h, C:/svn/trunk/HappyCloudService/Include/ConfUtils.cpp, C:/svn/trunk/HappyCloudService/Include/Version.cpp, C:/svn/trunk/HappyCloudService/poco-1.4.1p1/Foundation/include/Poco/Stopwatch.h, C:/svn/trunk/HappyCloudService/poco-1.4.1p1/Foundation/include/Poco/Timestamp.h, C:/svn/trunk/HappyCloudService/Include/HRTimer.cpp, C:/dev/android-ndk-r9c/sources/cxx-stl/gnu-libstdc++/4.6/include/bits/locale_classes.tcc, C:/dev/android-ndk-r9c/sources/cxx-stl/gnu-libstdc++/4.6/include/ext/type_traits.h, C:/dev/android-ndk-r9c/sources/cxx-stl/gnu-libstdc++/4.6/include/bits/stl_uninitialized.h, C:/dev/android-ndk-r9c/sources/cxx-stl/gnu-libstdc++/4.6/include/bits/stl_iterator_base_funcs.h, C:/dev/android-ndk-r9c/sources/cxx-stl/gnu-libstdc++/4.6/include/bits/list.tcc, C:/dev/android-ndk-r9c/sources/cxx-stl/gnu-libstdc++/4.6/include/bits/regex_grep_matcher.h, C:/dev/android-ndk-r9c/sources/cxx-stl/gnu-libstdc++/4.6/include/bits/vector.tcc, C:/dev/android-ndk-r9c/sources/cxx-stl/gnu-libstdc++/4.6/include/bits/regex.h, C:/dev/android-ndk-r9c/sources/cxx-stl/gnu-libstdc++/4.6/include/bits/stl_algo.h, C:/dev/android-ndk-r9c/sources/cxx-stl/gnu-libstdc++/4.6/include/bits/stl_list.h, C:/dev/android-ndk-r9c/sources/cxx-stl/gnu-libstdc++/4.6/include/exception, C:/svn/trunk/HappyCloudService/poco-1.4.1p1/Foundation/include/Poco/DateTimeFormatter.h, C:/dev/android-ndk-r9c/sources/cxx-stl/gnu-libstdc++/4.6/include/bits/stl_stack.h, C:/dev/android-ndk-r9c/sources/cxx-stl/gnu-libstdc++/4.6/include/bits/shared_ptr.h, C:/dev/android-ndk-r9c/sources/cxx-stl/gnu-libstdc++/4.6/include/bits/shared_ptr_base.h, C:/dev/android-ndk-r9c/sources/cxx-stl/gnu-libstdc++/4.6/include/bits/regex_grep_matcher.tcc, C:/dev/android-ndk-r9c/sources/cxx-stl/gnu-libstdc++/4.6/include/bits/regex_compiler.h, C:/dev/android-ndk-r9c/sources/cxx-stl/gnu-libstdc++/4.6/include/bits/regex_nfa.tcc, C:/dev/android-ndk-r9c/sources/cxx-stl/gnu-libstdc++/4.6/include/bits/regex_nfa.h, C:/dev/android-ndk-r9c/sources/cxx-stl/gnu-libstdc++/4.6/include/bits/regex_cursor.h, C:/dev/android-ndk-r9c/sources/cxx-stl/gnu-libstdc++/4.6/include/ext/concurrence.h, C:/dev/android-ndk-r9c/sources/cxx-stl/gnu-libstdc++/4.6/libs/armeabi/include/bits/ctype_inline.h, C:/dev/android-ndk-r9c/sources/cxx-stl/gnu-libstdc++/4.6/include/bits/locale_facets.h, C:/dev/android-ndk-r9c/sources/cxx-stl/gnu-libstdc++/4.6/include/bits/ios_base.h, C:/dev/android-ndk-r9c/sources/cxx-stl/gnu-libstdc++/4.6/include/functional, C:/dev/android-ndk-r9c/sources/cxx-stl/gnu-libstdc++/4.6/include/ext/atomicity.h, C:/dev/android-ndk-r9c/sources/cxx-stl/gnu-libstdc++/4.6/libs/armeabi/include/bits/gthr-default.h, C:/dev/android-ndk-r9c/platforms/android-17/arch-arm/usr/include/stdlib.h, C:/svn/trunk/HappyCloudService/Include/Utils.cpp, C:/svn/trunk/HappyCloudService/Include/HC_UI_MB.cpp, C:/dev/android-ndk-r9c/sources/cxx-stl/gnu-libstdc++/4.6/include/bits/postypes.h, C:/svn/trunk/HappyCloudService/Include/FileUtilsUnix.cpp, C:/svn/trunk/HappyCloudService/poco-1.4.1p1/Foundation/include/Poco/Thread.h, C:/svn/trunk/HappyCloudService/poco-1.4.1p1/Foundation/include/Poco/DirectoryIterator.h, C:/svn/trunk/HappyCloudService/poco-1.4.1p1/Foundation/include/Poco/Path.h, C:/svn/trunk/HappyCloudService/Include/FileUtils.h, C:/svn/trunk/HappyCloudService/Include/FileUtils.cpp, C:/dev/android-ndk-r9c/sources/cxx-stl/gnu-libstdc++/4.6/include/bits/deque.tcc, C:/svn/trunk/HappyCloudService/Include/LoggingSystem.h, C:/svn/trunk/HappyCloudService/poco-1.4.1p1/Foundation/include/Poco/Thread_POSIX.h, C:/svn/trunk/HappyCloudService/poco-1.4.1p1/Foundation/include/Poco/Process.h, C:/dev/android-ndk-r9c/sources/cxx-stl/gnu-libstdc++/4.6/include/bits/stl_deque.h, C:/svn/trunk/HappyCloudService/Include/log.cpp, C:/dev/android-ndk-r9c/platforms/android-17/arch-arm/usr/include/jni.h
OKOutput build
1>
Build started: Project: QuakeProgressive, Configuration: Debug Win32
1> VisualGDB: Executing prebuild actions
1> VisualGDB: Run “C:devandroid-ndk-r9cndk-build.cmd NDK_DEBUG=1 APP_PLATFORM=android-17 VGDB_VSCONFIG=Debug” in directory “C:svntrunkAndroidQuakeProgressive” on local computer
1> [armeabi] Gdbserver : [arm-linux-androideabi-4.6] libs/armeabi/gdbserver
1> [armeabi] Gdbsetup : libs/armeabi/gdb.setup
1> [armeabi] Install : libquakeprogressive.so => libs/armeabi/libquakeprogressive.so
1> VisualGDB: Run “C:apache-ant-1.9.0binant.bat debug” in directory “C:svntrunkAndroidQuakeProgressive” on local computer
1> Buildfile: C:svntrunkAndroidQuakeProgressivebuild.xml
1>
1> -set-mode-check:
1>
1> -set-debug-files:
1>
1> -check-env:
1> [checkenv] Android SDK Tools Revision 22.3.0
1> [checkenv] Installed at C:eclipsesdk
1>
1> -setup:
1> [echo] Project Name: QuakeProgressive
1> [gettype] Project Type: Application
1>
1> -set-debug-mode:
1>
1> -debug-obfuscation-check:
1>
1> -pre-build:
1>
1> -build-setup:
1> [getbuildtools] Using latest Build Tools: 19.0.1
1> [echo] Resolving Build Target for QuakeProgressive…
1> [gettarget] Project Target: Android 4.2.2
1> [gettarget] API level: 17
1> [echo]1> [echo] Creating output directories if needed…
1> [echo]1> [echo] Resolving Dependencies for QuakeProgressive…
1> [dependency] Library dependencies:
1> [dependency] No Libraries
1> [dependency]
1> [dependency]1> [echo]
1> [echo] Building Libraries with ‘debug’…
1> [subant] No sub-builds to iterate on
1>
1> -code-gen:
1> [mergemanifest] Found Deleted Target File
1> [mergemanifest] Merging AndroidManifest files into one.
1> [mergemanifest] Manifest merger disabled. Using project manifest only.
1> [echo] Handling aidl files…
1> [aidl] No AIDL files to compile.
1> [echo]1> [echo] Handling RenderScript files…
1> [echo]1> [echo] Handling Resources…
1> [aapt] Found Deleted Target File
1> [aapt] Generating resource IDs…
1> [echo]1> [echo] Handling BuildConfig class…
1> [buildconfig] No need to generate new BuildConfig.
1>
1> -pre-compile:
1>
1> -compile:
1> [javac] Compiling 1 source file to C:svntrunkAndroidQuakeProgressivebinclasses
1>
1> -post-compile:
1>
1> -obfuscate:
1>
1> -dex:
1> [dex] input: C:svntrunkAndroidQuakeProgressivebinclasses
1> [dex] Found Deleted Target File
1> [dex] Converting compiled files and external libraries into C:svntrunkAndroidQuakeProgressivebinclasses.dex…
1>
1> -crunch:
1> [crunch] Crunching PNG Files in source dir: C:svntrunkAndroidQuakeProgressiveres
1> [crunch] To destination dir: C:svntrunkAndroidQuakeProgressivebinres
1> [crunch] Crunched 0 PNG files to update cache
1>
1> -package-resources:
1> [aapt] Creating full resource package…
1>EXEC : [aapt] warning : AndroidManifest.xml already defines debuggable (in http://schemas.android.com/apk/res/android); using existing value in manifest.
1>
1> -package:
1> [apkbuilder] Found Deleted Target File
1> [apkbuilder] Creating QuakeProgressive-debug-unaligned.apk and signing it with a debug key…
1>
1> -post-package:
1>
1> -do-debug:
1> [zipalign] Running zip align on final apk…
1> [echo] Debug Package: C:svntrunkAndroidQuakeProgressivebinQuakeProgressive-debug.apk
1> [propertyfile] Updating property file: C:svntrunkAndroidQuakeProgressivebinbuild.prop
1>
1> -post-build:
1>
1> debug:
1>
1> BUILD SUCCESSFUL
1> Total time: 4 seconds
1> VisualGDB: Executing postbuild actions
========== Build: 1 succeeded, 0 failed, 0 up-to-date, 0 skipped ==========February 27, 2014 at 17:15 #2880ket
Based on the logs provided, the build is a debug build and the symbols for your app are loaded.
The message “No symbol “disassembly” in current context.” is a harmless warning to a gdb initialization command, it is not related to breakpoints not being set.
Please provide us with a full gdb log. For this, enable gdb logging on the GDB settings page in VisualGDB Project Properties. Then start debugging, replicate your scenario (make sure some breakpoints are set in the code before or during debugging), stop debugging and give us the log from your project directory.
March 1, 2014 at 17:15 #2881hcroyl
ParticipantHey,
Attaching a link to the log.
https://docs.google.com/document/d/1gQPziUV-P6Tur_Fq21KEAlxJN_yQGXm8da7Tos1pdJk/edit?usp=sharingI have noticed that the breakpoints will hit if:
1. I run the app
2. Click on home button
3. Return to my appOnly when i do that the breakpoints gets hit, which is very inconvenient..
how can i fix that?
Thanks.March 2, 2014 at 17:25 #2879ket
Based on the log you attached, the breakpoints are hit successfully. The log indicates no problems setting the breakpoints correctly. We would need to see the log where the breakpoints are not hit to be able to tell what the issue is. However, based on the log and the description of your workaround the breakpoints are even then probably set correctly.
Are you trying to set breakpoints in code that is called very early in the app startup? If so, please try setting the Android->Debug Options->Debug App Startup option.
