Sysprogs forums › Forums › VisualGDB › Breakpoint with hit count not working
- This topic has 2 replies, 2 voices, and was last updated 9 years, 6 months ago by
sidprice.
March 23, 2017 at 20:53 #10791
sidprice
ParticipantI have an embedded STM32F411RE proecjt. I have set a breakpoint in some code I need to debug, the breakpoint has a hit count of 2 but the target never breaks. If I interrupt execution I see that the conditional BP has been hit 12 times.
Here is the session log:
VisualGDB is licensed to Sid Price
C:\SysGCC\arm-eabi\bin\arm-eabi-gdb.exe –interpreter mi C:\DataRoot\Projects\bmp_windows_build\bmp_windows_build\VisualGDB\Release\blackmagic.elf
-gdb-version
=thread-group-added,id=”i1″
~”GNU gdb (GDB) 7.12\n”
~”Copyright (C) 2016 Free Software Foundation, Inc.\n”
~”This GDB was configured as \”–host=i686-pc-mingw32 –target=arm-eabi\”.\nType \”show configuration\” for configuration details.”
~”For help, type \”help\”.\n”
~”Reading symbols from C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\VisualGDB\\Release\\blackmagic.elf…”
~”done.\n”
^done
-list-features
-gdb-set print demangle off
^done
-break-insert -f main
^done,bkpt={number=”1″,type=”breakpoint”,disp=”keep”,enabled=”y”,addr=”0x08001e9a”,func=”main”,file=”main.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\main.c”,line=”54″,thread-groups=[“i1″],times=”0″,original-location=”main”}
target remote :2331
&”target remote :2331\n”
~”Remote debugging using :2331\n”
~”0x0800347a in _CC3100_WaitmS (waitTime=2000) at platforms/WifiF4/cc3100.c:61\n”
~”61\t\twhile ( theTargetTime > platform_time_ms() )\n”
*stopped,frame={addr=”0x0800347a”,func=”_CC3100_WaitmS”,args=[{name=”waitTime”,value=”2000″}],file=”platforms/WifiF4/cc3100.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\platforms\\WifiF4\\cc3100.c”,line=”61″},thread-id=”1″,stopped-threads=”all”
^done
mon reset
&”mon reset\n”
@”Resetting target\r\n”
^done
info shared
&”info shared\n”
~”No shared libraries loaded at this time.\n”
^done
load
&”load\n”
~”Loading section .text, size 0x223c8 lma 0x8000000\n”
+download,{section=”.text”,section-size=”140232″,total-size=”1087200″}
~”Loading section .data, size 0xb7c lma 0x80223c8\n”
+download,{section=”.data”,section-size=”2940″,total-size=”1087200″}
~”Start address 0x8012e20, load size 143172\n”
~”Transfer rate: 23302 KB/sec, 14317 bytes/write.\n”
^done
-data-evaluate-expression “sizeof(void *)”
^done,value=”4″
-data-evaluate-expression “sizeof(int)”
^done,value=”4″
-data-evaluate-expression “sizeof(short)”
^done,value=”2″
-data-evaluate-expression “sizeof(long)”
^done,value=”4″
-data-evaluate-expression “sizeof(long long)”
^done,value=”8″
-data-evaluate-expression “sizeof(char)”
^done,value=”1″
-data-evaluate-expression “sizeof(wchar_t)”
^done,value=”4″
-data-evaluate-expression “sizeof(float)”
^done,value=”4″
-data-evaluate-expression “sizeof(double)”
^done,value=”8″
-data-evaluate-expression “sizeof(long double)”
^done,value=”8″
info target
&”info target\n”
~”Symbols from \”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\VisualGDB\\Release\\blackmagic.elf\”.\n”
~”Remote serial target in gdb-specific protocol:\n”
~”Debugging a target over a serial line.\n”
~”\tWhile running this, GDB does not access memory from…\n”
~”Local exec file:\n”
~”\t`C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\VisualGDB\\Release\\blackmagic.elf’, file type elf32-littlearm.\n”
~”\tEntry point: 0x8012e20\n”
~”\t0x08000000 – 0x080223c8 is .text\n”
~”\t0x080223c8 – 0x080223c8 is .preinit_array\n”
~”\t0x080223c8 – 0x080223c8 is .init_array\n”
~”\t0x080223c8 – 0x080223c8 is .fini_array\n”
~”\t0x20000000 – 0x20000b7c is .data\n”
~”\t0x20000b7c – 0x200021d4 is .bss\n”
^done
-break-insert -f C:/DataRoot/Projects/bmp_windows_build/bmp_windows_build/bmp_windows_build/platforms/WifiF4/cc3100.c:434
^done,bkpt={number=”2″,type=”breakpoint”,disp=”keep”,enabled=”y”,addr=”0x08003946″,func=”_CC3100_Setup”,file=”platforms/WifiF4/cc3100.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\platforms\\WifiF4\\cc3100.c”,line=”434″,thread-groups=[“i1″],times=”0″,original-location=”C:/DataRoot/Projects/bmp_windows_build/bmp_windows_build/bmp_windows_build/platforms/WifiF4/cc3100.c:434″}
-break-after 2 0
^done
-break-disable 2
^done
info symbol 0x8003946
&”info symbol 0x8003946\n”
~”_CC3100_Setup + 374 in section .text\n”
^done
info line *0x8003946
&”info line *0x8003946\n”
~”Line 434 of \”platforms/WifiF4/cc3100.c\” starts at address 0x8003946 <_CC3100_Setup+374> and ends at 0x8003954 <_CC3100_Setup+388>.\n”
^done
-file-list-exec-source-files
^done,files=[{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdlib/wcrtomb.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/stdlib/../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdlib/wcrtomb.c”},{file=”/cygdrive/q/gnu/auto/newlib-2.4.0.20160923/newlib/libc/locale/setlocale.h”,fullname=”/cygdrive/q/gnu/auto/newlib-2.4.0.20160923/newlib/libc/locale/setlocale.h”},{file=”/usr/local/lib/gcc/arm-eabi/6.2.0/include/stddef.h”,fullname=”/usr/local/lib/gcc/arm-eabi/6.2.0/include/stddef.h”},{file=”/q/gnu/auto/newlib-2.4.0.20160923/newlib/libc/include/sys/lock.h”,fullname=”/q/gnu/auto/newlib-2.4.0.20160923/newlib/libc/include/sys/lock.h”},{file=”/q/gnu/auto/newlib-2.4.0.20160923/newlib/libc/include/sys/_types.h”,fullname=”/q/gnu/auto/newlib-2.4.0.20160923/newlib/libc/include/sys/_types.h”},{file=”/q/gnu/auto/newlib-2.4.0.20160923/newlib/libc/include/sys/reent.h”,fullname=”/q/gnu/auto/newlib-2.4.0.20160923/newlib/libc/include/sys/reent.h”},{file=”/q/gnu/auto/newlib-2.4.0.20160923/newlib/libc/include/wchar.h”,fullname=”/q/gnu/auto/newlib-2.4.0.20160923/newlib/libc/include/wchar.h”},{file=”/q/gnu/auto/newlib-2.4.0.20160923/newlib/libc/include/stdlib.h”,fullname=”/q/gnu/auto/newlib-2.4.0.20160923/newlib/libc/include/stdlib.h”},{file=”/q/gnu/auto/newlib-2.4.0.20160923/newlib/libc/include/sys/errno.h”,fullname=”/q/gnu/auto/newlib-2.4.0.20160923/newlib/libc/include/sys/errno.h”},{file=”/q/gnu/auto/newlib-2.4.0.20160923/newlib/libc/include/locale.h”,fullname=”/q/gnu/auto/newlib-2.4.0.20160923/newlib/libc/include/locale.h”},{file=”/cygdrive/q/gnu/auto/newlib-2.4.0.20160923/newlib/libc/stdlib/local.h”,fullname=”/cygdrive/q/gnu/auto/newlib-2.4.0.20160923/newlib/libc/stdlib/local.h”},{file=”cm3/vector.c”,fullname=”C:\\DataRoot\\Projects\\libopencm3_windows\\libopencm3_stm32f4\\cm3\\vector.c”},{file=”cm3/../dispatch/../stm32/f4/vector_chipset.c”,fullname=”C:\\DataRoot\\Projects\\libopencm3_windows\\libopencm3_stm32f4\\stm32\\f4\\vector_chipset.c”},{file=”c:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\machine/_default_types.h”,fullname=”c:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\machine\\_default_types.h”},{file=”c:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\sys/_stdint.h”,fullname=”c:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\sys\\_stdint.h”},{file=”include/libopencm3/cm3/vector.h”,fullname=”C:\\DataRoot\\Projects\\libopencm3_windows\\libopencm3_stm32f4\\include\\libopencm3\\cm3\\vector.h”},{file=”platforms/WifiF4/cc3100.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\platforms\\WifiF4\\cc3100.c”},{file=”C:/DataRoot/Projects/bmp_windows_build/bmp_windows_build/bmp_windows_build/platforms/stm32/gpio.h”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\platforms\\stm32\\gpio.h”},{file=”c:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\machine/_default_types.h”,fullname=”c:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\machine\\_default_types.h”},{file=”c:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\sys/_stdint.h”,fullname=”c:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\sys\\_stdint.h”},{file=”c:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\sys/lock.h”,fullname=”c:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\sys\\lock.h”},{file=”c:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\sys/_types.h”,fullname=”c:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\sys\\_types.h”},{file=”c:\\sysgcc\\arm-eabi\\lib\\gcc\\arm-eabi\\6.2.0\\include/stddef.h”,fullname=”c:\\sysgcc\\arm-eabi\\lib\\gcc\\arm-eabi\\6.2.0\\include\\stddef.h”},{file=”c:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\sys/reent.h”,fullname=”c:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\sys\\reent.h”},{file=”c:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include/stdlib.h”,fullname=”c:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\stdlib.h”},{file=”c:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\sys/types.h”,fullname=”c:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\sys\\types.h”},{file=”C:/DataRoot/Projects/bmp_windows_build/bmp_windows_build/bmp_windows_build/platforms/stm32/timing_stm32.h”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\platforms\\stm32\\timing_stm32.h”},{file=”platforms/WifiF4/platform.h”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\platforms\\WifiF4\\platform.h”},{file=”../../../libopencm3_windows/libopencm3_stm32f4/include/libopencm3/usb/usbd.h”,fullname=”C:\\DataRoot\\Projects\\libopencm3_windows\\libopencm3_stm32f4\\include\\libopencm3\\usb\\usbd.h”},{file=”platforms/common/cdcacm.h”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\platforms\\common\\cdcacm.h”},{file=”include/morse.h”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\include\\morse.h”},{file=”../../../libopencm3_windows/libopencm3_stm32f4/include/libopencm3/stm32/f4/rcc.h”,fullname=”C:\\DataRoot\\Projects\\libopencm3_windows\\libopencm3_stm32f4\\include\\libopencm3\\stm32\\f4\\rcc.h”},{file=”../../../libopencm3_windows/libopencm3_stm32f4/include/libopencm3/stm32/common/exti_common_all.h”,fullname=”C:\\DataRoot\\Projects\\libopencm3_windows\\libopencm3_stm32f4\\include\\libopencm3\\stm32\\common\\exti_common_all.h”},{file=”simplelink/include/user.h”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\simplelink\\include\\user.h”},{file=”simplelink/include/socket.h”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\simplelink\\include\\socket.h”},{file=”simplelink/include/netapp.h”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\simplelink\\include\\netapp.h”},{file=”simplelink/include/wlan.h”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\simplelink\\include\\wlan.h”},{file=”simplelink/include/device.h”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\simplelink\\include\\device.h”},{file=”simplelink/include/netcfg.h”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\simplelink\\include\\netcfg.h”},{file=”simplelink/include/wlan_rx_filters.h”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\simplelink\\include\\wlan_rx_filters.h”},{file=”main.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\main.c”},{file=”c:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\machine/_default_types.h”,fullname=”c:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\machine\\_default_types.h”},{file=”c:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\sys/_stdint.h”,fullname=”c:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\sys\\_stdint.h”},{file=”c:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\sys/lock.h”,fullname=”c:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\sys\\lock.h”},{file=”c:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\sys/_types.h”,fullname=”c:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\sys\\_types.h”},{file=”c:\\sysgcc\\arm-eabi\\lib\\gcc\\arm-eabi\\6.2.0\\include/stddef.h”,fullname=”c:\\sysgcc\\arm-eabi\\lib\\gcc\\arm-eabi\\6.2.0\\include\\stddef.h”},{file=”c:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\sys/reent.h”,fullname=”c:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\sys\\reent.h”},{file=”c:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include/stdlib.h”,fullname=”c:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\stdlib.h”},{file=”C:/DataRoot/Projects/bmp_windows_build/bmp_windows_build/bmp_windows_build/platforms/stm32/timing_stm32.h”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\platforms\\stm32\\timing_stm32.h”},{file=”c:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\machine/setjmp.h”,fullname=”c:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\machine\\setjmp.h”},{file=”platforms/WifiF4/platform.h”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\platforms\\WifiF4\\platform.h”},{file=”../../../libopencm3_windows/libopencm3_stm32f4/include/libopencm3/usb/usbd.h”,fullname=”C:\\DataRoot\\Projects\\libopencm3_windows\\libopencm3_stm32f4\\include\\libopencm3\\usb\\usbd.h”},{file=”include/exception.h”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\include\\exception.h”},{file=”include/morse.h”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\include\\morse.h”},{file=”../../../../../../gcc-6.2.0/libgcc/config/arm/ieee754-df.S”,fullname=”/q/gnu/auto/gcc-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/libgcc/../../../../../../gcc-6.2.0/libgcc/config/arm/ieee754-df.S”},{file=”../../../../../../gcc-6.2.0/libgcc/config/arm/ieee754-df.S”,fullname=”/q/gnu/auto/gcc-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/libgcc/../../../../../../gcc-6.2.0/libgcc/config/arm/ieee754-df.S”},{file=”../../../../../../gcc-6.2.0/libgcc/config/arm/ieee754-df.S”,fullname=”/q/gnu/auto/gcc-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/libgcc/../../../../../../gcc-6.2.0/libgcc/config/arm/ieee754-df.S”},{file=”../../../../../../gcc-6.2.0/libgcc/config/arm/ieee754-df.S”,fullname=”/q/gnu/auto/gcc-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/libgcc/../../../../../../gcc-6.2.0/libgcc/config/arm/ieee754-df.S”},{file=”../../../../../../gcc-6.2.0/libgcc/config/arm/ieee754-df.S”,fullname=”/q/gnu/auto/gcc-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/libgcc/../../../../../../gcc-6.2.0/libgcc/config/arm/ieee754-df.S”},{file=”/cygdrive/q/gnu/auto/newlib-2.4.0.20160923/newlib/libc/locale/setlocale.h”,fullname=”/cygdrive/q/gnu/auto/newlib-2.4.0.20160923/newlib/libc/locale/setlocale.h”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libc/reent/isattyr.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/reent/../../../../../../../../newlib-2.4.0.20160923/newlib/libc/reent/isattyr.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libc/reent/fstatr.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/reent/../../../../../../../../newlib-2.4.0.20160923/newlib/libc/reent/fstatr.c”},{file=”/q/gnu/auto/newlib-2.4.0.20160923/newlib/libc/include/stdio.h”,fullname=”/q/gnu/auto/newlib-2.4.0.20160923/newlib/libc/include/stdio.h”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdio/fputwc.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/stdio/../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdio/fputwc.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdio/fclose.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/stdio/../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdio/fclose.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdio/wbuf.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/stdio/../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdio/wbuf.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdio/vfprintf.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/stdio/../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdio/vfprintf.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdio/sccl.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/stdio/../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdio/sccl.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libc/reent/reent.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/reent/../../../../../../../../newlib-2.4.0.20160923/newlib/libc/reent/reent.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdlib/mallocr.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/stdlib/../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdlib/mallocr.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libc/reent/readr.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/reent/../../../../../../../../newlib-2.4.0.20160923/newlib/libc/reent/readr.c”},{file=”/q/gnu/auto/newlib-2.4.0.20160923/newlib/libc/include/stdio.h”,fullname=”/q/gnu/auto/newlib-2.4.0.20160923/newlib/libc/include/stdio.h”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdio/putc.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/stdio/../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdio/putc.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdlib/mprec.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/stdlib/../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdlib/mprec.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libc/string/memmove.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/string/../../../../../../../../newlib-2.4.0.20160923/newlib/libc/string/memmove.c”},{file=”../../../../../../../../../newlib-2.4.0.20160923/newlib/libc/machine/arm/memchr.S”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/machine/arm/../../../../../../../../../newlib-2.4.0.20160923/newlib/libc/machine/arm/memchr.S”},{file=”/cygdrive/q/gnu/auto/newlib-2.4.0.20160923/newlib/libc/locale/setlocale.h”,fullname=”/cygdrive/q/gnu/auto/newlib-2.4.0.20160923/newlib/libc/locale/setlocale.h”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdlib/mbrtowc.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/stdlib/../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdlib/mbrtowc.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdio/makebuf.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/stdio/../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdio/makebuf.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libc/reent/lseekr.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/reent/../../../../../../../../newlib-2.4.0.20160923/newlib/libc/reent/lseekr.c”},{file=”/cygdrive/q/gnu/auto/newlib-2.4.0.20160923/newlib/libc/locale/setlocale.h”,fullname=”/cygdrive/q/gnu/auto/newlib-2.4.0.20160923/newlib/libc/locale/setlocale.h”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libc/locale/localeconv.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/locale/../../../../../../../../newlib-2.4.0.20160923/newlib/libc/locale/localeconv.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libc/ctype/iswspace.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/ctype/../../../../../../../../newlib-2.4.0.20160923/newlib/libc/ctype/iswspace.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdio/fwalk.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/stdio/../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdio/fwalk.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdio/fvwrite.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/stdio/../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdio/fvwrite.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdlib/mallocr.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/stdlib/../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdlib/mallocr.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdio/findfp.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/stdio/../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdio/findfp.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdio/fflush.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/stdio/../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdio/fflush.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libc/errno/errno.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/errno/../../../../../../../../newlib-2.4.0.20160923/newlib/libc/errno/errno.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdlib/dtoa.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/stdlib/../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdlib/dtoa.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libc/ctype/ctype_.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/ctype/../../../../../../../../newlib-2.4.0.20160923/newlib/libc/ctype/ctype_.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libc/reent/closer.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/reent/../../../../../../../../newlib-2.4.0.20160923/newlib/libc/reent/closer.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdio/wsetup.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/stdio/../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdio/wsetup.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libc/reent/writer.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/reent/../../../../../../../../newlib-2.4.0.20160923/newlib/libc/reent/writer.c”},{file=”/cygdrive/q/gnu/auto/newlib-2.4.0.20160923/newlib/libc/locale/setlocale.h”,fullname=”/cygdrive/q/gnu/auto/newlib-2.4.0.20160923/newlib/libc/locale/setlocale.h”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdlib/wctomb_r.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/stdlib/../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdlib/wctomb_r.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdio/vfprintf.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/stdio/../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdio/vfprintf.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdio/vasiprintf.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/stdio/../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdio/vasiprintf.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdio/ungetc.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/stdio/../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdio/ungetc.c”},{file=”/cygdrive/q/gnu/auto/newlib-2.4.0.20160923/newlib/libc/sys/arm/swi.h”,fullname=”/cygdrive/q/gnu/auto/newlib-2.4.0.20160923/newlib/libc/sys/arm/swi.h”},{file=”../../../../../../../../../newlib-2.4.0.20160923/newlib/libc/sys/arm/syscalls.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/sys/arm/../../../../../../../../../newlib-2.4.0.20160923/newlib/libc/sys/arm/syscalls.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdio/vfscanf.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/stdio/../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdio/vfscanf.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdio/vfprintf.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/stdio/../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdio/vfprintf.c”},{file=”/cygdrive/q/gnu/auto/newlib-2.4.0.20160923/newlib/libc/locale/setlocale.h”,fullname=”/cygdrive/q/gnu/auto/newlib-2.4.0.20160923/newlib/libc/locale/setlocale.h”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdlib/strtoul.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/stdlib/../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdlib/strtoul.c”},{file=”/cygdrive/q/gnu/auto/newlib-2.4.0.20160923/newlib/libc/locale/setlocale.h”,fullname=”/cygdrive/q/gnu/auto/newlib-2.4.0.20160923/newlib/libc/locale/setlocale.h”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdlib/strtol.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/stdlib/../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdlib/strtol.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libc/string/strtok_r.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/string/../../../../../../../../newlib-2.4.0.20160923/newlib/libc/string/strtok_r.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libc/string/strtok.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/string/../../../../../../../../newlib-2.4.0.20160923/newlib/libc/string/strtok.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libc/string/strncpy.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/string/../../../../../../../../newlib-2.4.0.20160923/newlib/libc/string/strncpy.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libc/string/strncmp.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/string/../../../../../../../../newlib-2.4.0.20160923/newlib/libc/string/strncmp.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libc/string/strncasecmp.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/string/../../../../../../../../newlib-2.4.0.20160923/newlib/libc/string/strncasecmp.c”},{file=”/cygdrive/q/gnu/auto/newlib-2.4.0.20160923/newlib/libc/machine/arm/strlen-armv7.S”,fullname=”/cygdrive/q/gnu/auto/newlib-2.4.0.20160923/newlib/libc/machine/arm/strlen-armv7.S”},{file=”../../../../../../../../../newlib-2.4.0.20160923/newlib/libc/machine/arm/strcpy.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/machine/arm/../../../../../../../../../newlib-2.4.0.20160923/newlib/libc/machine/arm/strcpy.c”},{file=”/cygdrive/q/gnu/auto/newlib-2.4.0.20160923/newlib/libc/machine/arm/strcmp-armv7.S”,fullname=”/cygdrive/q/gnu/auto/newlib-2.4.0.20160923/newlib/libc/machine/arm/strcmp-armv7.S”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdio/stdio.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/stdio/../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdio/stdio.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdio/sniprintf.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/stdio/../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdio/sniprintf.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdio/siscanf.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/stdio/../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdio/siscanf.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdio/siprintf.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/stdio/../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdio/siprintf.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libc/reent/signalr.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/reent/../../../../../../../../newlib-2.4.0.20160923/newlib/libc/reent/signalr.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libc/signal/signal.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/signal/../../../../../../../../newlib-2.4.0.20160923/newlib/libc/signal/signal.c”},{file=”../../../../../../../../../newlib-2.4.0.20160923/newlib/libc/machine/arm/setjmp.S”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/machine/arm/../../../../../../../../../newlib-2.4.0.20160923/newlib/libc/machine/arm/setjmp.S”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libc/reent/sbrkr.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/reent/../../../../../../../../newlib-2.4.0.20160923/newlib/libc/reent/sbrkr.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdio/puts.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/stdio/../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdio/puts.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdio/putchar.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/stdio/../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdio/putchar.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdio/printf.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/stdio/../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdio/printf.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdlib/mlock.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/stdlib/../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdlib/mlock.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libc/string/memset.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/string/../../../../../../../../newlib-2.4.0.20160923/newlib/libc/string/memset.c”},{file=”/cygdrive/q/gnu/auto/newlib-2.4.0.20160923/newlib/libc/machine/arm/memcpy-armv7m.S”,fullname=”/cygdrive/q/gnu/auto/newlib-2.4.0.20160923/newlib/libc/machine/arm/memcpy-armv7m.S”},{file=”/cygdrive/q/gnu/auto/newlib-2.4.0.20160923/newlib/libc/locale/setlocale.h”,fullname=”/cygdrive/q/gnu/auto/newlib-2.4.0.20160923/newlib/libc/locale/setlocale.h”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdlib/mbtowc_r.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/stdlib/../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdlib/mbtowc_r.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdlib/mallocr.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/stdlib/../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdlib/mallocr.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdlib/malloc.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/stdlib/../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdlib/malloc.c”},{file=”/cygdrive/q/gnu/auto/newlib-2.4.0.20160923/newlib/libc/locale/setlocale.h”,fullname=”/cygdrive/q/gnu/auto/newlib-2.4.0.20160923/newlib/libc/locale/setlocale.h”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libc/locale/locale.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/locale/../../../../../../../../newlib-2.4.0.20160923/newlib/libc/locale/locale.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libc/reent/impure.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/reent/../../../../../../../../newlib-2.4.0.20160923/newlib/libc/reent/impure.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdlib/mallocr.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/stdlib/../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdlib/mallocr.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdlib/calloc.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/stdlib/../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdlib/calloc.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdlib/atol.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/stdlib/../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdlib/atol.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdlib/atoi.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/stdlib/../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdlib/atoi.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdlib/abort.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/stdlib/../../../../../../../../newlib-2.4.0.20160923/newlib/libc/stdlib/abort.c”},{file=”stm32/f4/pwr.c”,fullname=”C:\\DataRoot\\Projects\\libopencm3_windows\\libopencm3_stm32f4\\stm32\\f4\\pwr.c”},{file=”stm32/common/flash_common_f234.c”,fullname=”C:\\DataRoot\\Projects\\libopencm3_windows\\libopencm3_stm32f4\\stm32\\common\\flash_common_f234.c”},{file=”usb/usb_standard.c”,fullname=”C:\\DataRoot\\Projects\\libopencm3_windows\\libopencm3_stm32f4\\usb\\usb_standard.c”},{file=”usb/usb_fx07_common.c”,fullname=”C:\\DataRoot\\Projects\\libopencm3_windows\\libopencm3_stm32f4\\usb\\usb_fx07_common.c”},{file=”usb/usb_f107.c”,fullname=”C:\\DataRoot\\Projects\\libopencm3_windows\\libopencm3_stm32f4\\usb\\usb_f107.c”},{file=”usb/usb_control.c”,fullname=”C:\\DataRoot\\Projects\\libopencm3_windows\\libopencm3_stm32f4\\usb\\usb_control.c”},{file=”usb/usb.c”,fullname=”C:\\DataRoot\\Projects\\libopencm3_windows\\libopencm3_stm32f4\\usb\\usb.c”},{file=”stm32/f4/rcc.c”,fullname=”C:\\DataRoot\\Projects\\libopencm3_windows\\libopencm3_stm32f4\\stm32\\f4\\rcc.c”},{file=”stm32/f4/adc.c”,fullname=”C:\\DataRoot\\Projects\\libopencm3_windows\\libopencm3_stm32f4\\stm32\\f4\\adc.c”},{file=”stm32/common/usart_common_f124.c”,fullname=”C:\\DataRoot\\Projects\\libopencm3_windows\\libopencm3_stm32f4\\stm32\\common\\usart_common_f124.c”},{file=”stm32/common/usart_common_all.c”,fullname=”C:\\DataRoot\\Projects\\libopencm3_windows\\libopencm3_stm32f4\\stm32\\common\\usart_common_all.c”},{file=”stm32/common/timer_common_f0234.c”,fullname=”C:\\DataRoot\\Projects\\libopencm3_windows\\libopencm3_stm32f4\\stm32\\common\\timer_common_f0234.c”},{file=”stm32/common/timer_common_all.c”,fullname=”C:\\DataRoot\\Projects\\libopencm3_windows\\libopencm3_stm32f4\\stm32\\common\\timer_common_all.c”},{file=”stm32/common/spi_common_l1f124.c”,fullname=”C:\\DataRoot\\Projects\\libopencm3_windows\\libopencm3_stm32f4\\stm32\\common\\spi_common_l1f124.c”},{file=”stm32/common/spi_common_all.c”,fullname=”C:\\DataRoot\\Projects\\libopencm3_windows\\libopencm3_stm32f4\\stm32\\common\\spi_common_all.c”},{file=”stm32/common/rcc_common_all.c”,fullname=”C:\\DataRoot\\Projects\\libopencm3_windows\\libopencm3_stm32f4\\stm32\\common\\rcc_common_all.c”},{file=”stm32/common/gpio_common_f0234.c”,fullname=”C:\\DataRoot\\Projects\\libopencm3_windows\\libopencm3_stm32f4\\stm32\\common\\gpio_common_f0234.c”},{file=”stm32/common/gpio_common_all.c”,fullname=”C:\\DataRoot\\Projects\\libopencm3_windows\\libopencm3_stm32f4\\stm32\\common\\gpio_common_all.c”},{file=”stm32/common/exti_common_all.c”,fullname=”C:\\DataRoot\\Projects\\libopencm3_windows\\libopencm3_stm32f4\\stm32\\common\\exti_common_all.c”},{file=”stm32/common/adc_common_v1.c”,fullname=”C:\\DataRoot\\Projects\\libopencm3_windows\\libopencm3_stm32f4\\stm32\\common\\adc_common_v1.c”},{file=”cm3/../dispatch/../stm32/f4/vector_chipset.c”,fullname=”C:\\DataRoot\\Projects\\libopencm3_windows\\libopencm3_stm32f4\\stm32\\f4\\vector_chipset.c”},{file=”cm3/systick.c”,fullname=”C:\\DataRoot\\Projects\\libopencm3_windows\\libopencm3_stm32f4\\cm3\\systick.c”},{file=”cm3/scb.c”,fullname=”C:\\DataRoot\\Projects\\libopencm3_windows\\libopencm3_stm32f4\\cm3\\scb.c”},{file=”cm3/nvic.c”,fullname=”C:\\DataRoot\\Projects\\libopencm3_windows\\libopencm3_stm32f4\\cm3\\nvic.c”},{file=”target/target.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\target\\target.c”},{file=”target/swdptap_generic.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\target\\swdptap_generic.c”},{file=”target/stm32l4.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\target\\stm32l4.c”},{file=”target/stm32l0.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\target\\stm32l0.c”},{file=”target/stm32f4.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\target\\stm32f4.c”},{file=”target/stm32f1.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\target\\stm32f1.c”},{file=”target/samd.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\target\\samd.c”},{file=”target/sam4l.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\target\\sam4l.c”},{file=”target/sam3x.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\target\\sam3x.c”},{file=”target/nrf51.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\target\\nrf51.c”},{file=”target/lpc_common.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\target\\lpc_common.c”},{file=”target/lpc43xx.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\target\\lpc43xx.c”},{file=”target/lpc15xx.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\target\\lpc15xx.c”},{file=”target/lpc11xx.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\target\\lpc11xx.c”},{file=”target/lmi.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\target\\lmi.c”},{file=”target/kinetis.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\target\\kinetis.c”},{file=”target/jtag_scan.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\target\\jtag_scan.c”},{file=”target/jtagtap_generic.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\target\\jtagtap_generic.c”},{file=”target/efm32.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\target\\efm32.c”},{file=”target/adiv5.h”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\target\\adiv5.h”},{file=”target/cortexm.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\target\\cortexm.c”},{file=”target/adiv5.h”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\target\\adiv5.h”},{file=”target/cortexa.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\target\\cortexa.c”},{file=”target/adiv5.h”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\target\\adiv5.h”},{file=”target/adiv5_swdp.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\target\\adiv5_swdp.c”},{file=”target/adiv5_jtagdp.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\target\\adiv5_jtagdp.c”},{file=”target/adiv5.h”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\target\\adiv5.h”},{file=”target/adiv5.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\target\\adiv5.c”},{file=”simplelink/source/wlan.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\simplelink\\source\\wlan.c”},{file=”simplelink/source/socket.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\simplelink\\source\\socket.c”},{file=”simplelink/source/nonos.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\simplelink\\source\\nonos.c”},{file=”simplelink/source/netcfg.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\simplelink\\source\\netcfg.c”},{file=”simplelink/source/netapp.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\simplelink\\source\\netapp.c”},{file=”simplelink/source/driver.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\simplelink\\source\\driver.c”},{file=”simplelink/source/device.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\simplelink\\source\\device.c”},{file=”platforms/WifiF4/WiFi_Server.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\platforms\\WifiF4\\WiFi_Server.c”},{file=”C:/DataRoot/Projects/bmp_windows_build/bmp_windows_build/bmp_windows_build/platforms/stm32/gpio.h”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\platforms\\stm32\\gpio.h”},{file=”platforms/WifiF4/platform.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\platforms\\WifiF4\\platform.c”},{file=”C:/DataRoot/Projects/bmp_windows_build/bmp_windows_build/bmp_windows_build/platforms/stm32/gpio.h”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\platforms\\stm32\\gpio.h”},{file=”C:/DataRoot/Projects/bmp_windows_build/bmp_windows_build/bmp_windows_build/platforms/stm32/gpio.h”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\platforms\\stm32\\gpio.h”},{file=”platforms/stm32/usbuart.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\platforms\\stm32\\usbuart.c”},{file=”platforms/stm32/traceswo.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\platforms\\stm32\\traceswo.c”},{file=”C:/DataRoot/Projects/bmp_windows_build/bmp_windows_build/bmp_windows_build/platforms/stm32/gpio.h”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\platforms\\stm32\\gpio.h”},{file=”platforms/stm32/timing_stm32.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\platforms\\stm32\\timing_stm32.c”},{file=”platforms/stm32/serialno.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\platforms\\stm32\\serialno.c”},{file=”platforms/WifiF4/platform.h”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\platforms\\WifiF4\\platform.h”},{file=”C:/DataRoot/Projects/bmp_windows_build/bmp_windows_build/bmp_windows_build/platforms/stm32/gpio.h”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\platforms\\stm32\\gpio.h”},{file=”platforms/stm32/jtagtap.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\platforms\\stm32\\jtagtap.c”},{file=”platforms/stm32/gdb_if.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\platforms\\stm32\\gdb_if.c”},{file=”platforms/common/timing.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\platforms\\common\\timing.c”},{file=”C:/DataRoot/Projects/bmp_windows_build/bmp_windows_build/bmp_windows_build/platforms/stm32/gpio.h”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\platforms\\stm32\\gpio.h”},{file=”platforms/common/swdptap.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\platforms\\common\\swdptap.c”},{file=”platforms/common/cdcacm.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\platforms\\common\\cdcacm.c”},{file=”morse.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\morse.c”},{file=”hex_utils.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\hex_utils.c”},{file=”gdb_packet.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\gdb_packet.c”},{file=”C:/DataRoot/Projects/bmp_windows_build/bmp_windows_build/bmp_windows_build/platforms/stm32/gpio.h”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\platforms\\stm32\\gpio.h”},{file=”gdb_main.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\gdb_main.c”},{file=”gdb_hostio.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\gdb_hostio.c”},{file=”exception.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\exception.c”},{file=”crc32.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\crc32.c”},{file=”platforms/WifiF4/platform.h”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\platforms\\WifiF4\\platform.h”},{file=”command.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\command.c”}]
-break-insert -f C:/DataRoot/Projects/bmp_windows_build/bmp_windows_build/bmp_windows_build/platforms/WifiF4/cc3100.c:404
^done,bkpt={number=”3″,type=”breakpoint”,disp=”keep”,enabled=”y”,addr=”0x080038de”,func=”_CC3100_Setup”,file=”platforms/WifiF4/cc3100.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\platforms\\WifiF4\\cc3100.c”,line=”404″,thread-groups=[“i1″],times=”0″,original-location=”C:/DataRoot/Projects/bmp_windows_build/bmp_windows_build/bmp_windows_build/platforms/WifiF4/cc3100.c:404″}
-break-after 3 0
^done
-break-disable 3
^done
info symbol 0x80038de
&”info symbol 0x80038de\n”
~”_CC3100_Setup + 270 in section .text\n”
^done
info line *0x80038de
&”info line *0x80038de\n”
~”Line 404 of \”platforms/WifiF4/cc3100.c\” starts at address 0x80038de <_CC3100_Setup+270> and ends at 0x80038f2 <_CC3100_Setup+290>.\n”
^done
-break-insert -f C:/DataRoot/Projects/bmp_windows_build/bmp_windows_build/bmp_windows_build/platforms/WifiF4/cc3100.c:450
^done,bkpt={number=”4″,type=”breakpoint”,disp=”keep”,enabled=”y”,addr=”0x0800398a”,func=”_CC3100_Setup”,file=”platforms/WifiF4/cc3100.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\platforms\\WifiF4\\cc3100.c”,line=”450″,thread-groups=[“i1″],times=”0″,original-location=”C:/DataRoot/Projects/bmp_windows_build/bmp_windows_build/bmp_windows_build/platforms/WifiF4/cc3100.c:450″}
-break-after 4 0
^done
-break-disable 4
^done
info symbol 0x800398a
&”info symbol 0x800398a\n”
~”_CC3100_Setup + 442 in section .text\n”
^done
info line *0x800398a
&”info line *0x800398a\n”
~”Line 450 of \”platforms/WifiF4/cc3100.c\” starts at address 0x800398a <_CC3100_Setup+442> and ends at 0x800398c <_CC3100_Setup+444>.\n”
^done
-break-insert -f C:/DataRoot/Projects/bmp_windows_build/bmp_windows_build/bmp_windows_build/platforms/WifiF4/platform.c:349
^done,bkpt={number=”5″,type=”breakpoint”,disp=”keep”,enabled=”y”,addr=”0x08004368″,func=”platform_process_menu_input”,file=”platforms/WifiF4/platform.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\platforms\\WifiF4\\platform.c”,line=”349″,thread-groups=[“i1″],times=”0″,original-location=”C:/DataRoot/Projects/bmp_windows_build/bmp_windows_build/bmp_windows_build/platforms/WifiF4/platform.c:349″}
-break-after 5 0
^done
-break-disable 5
^done
info symbol 0x8004368
&”info symbol 0x8004368\n”
~”platform_process_menu_input + 12 in section .text\n”
^done
info line *0x8004368
&”info line *0x8004368\n”
~”Line 349 of \”platforms/WifiF4/platform.c\” starts at address 0x8004368 <platform_process_menu_input+12> and ends at 0x8004376 <platform_process_menu_input+26>.\n”
^done
-break-insert -f C:/DataRoot/Projects/bmp_windows_build/bmp_windows_build/bmp_windows_build/platforms/WifiF4/WiFi_Server.c:54
^done,bkpt={number=”6″,type=”breakpoint”,disp=”keep”,enabled=”y”,addr=”0x0800479e”,func=”WiFi_ServerProcess”,file=”platforms/WifiF4/WiFi_Server.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\platforms\\WifiF4\\WiFi_Server.c”,line=”54″,thread-groups=[“i1″],times=”0″,original-location=”C:/DataRoot/Projects/bmp_windows_build/bmp_windows_build/bmp_windows_build/platforms/WifiF4/WiFi_Server.c:54″}
-break-after 6 0
^done
-break-disable 6
^done
info symbol 0x800479e
&”info symbol 0x800479e\n”
~”WiFi_ServerProcess + 30 in section .text\n”
^done
info line *0x800479e
&”info line *0x800479e\n”
~”Line 59 of \”platforms/WifiF4/WiFi_Server.c\” starts at address 0x800479e <WiFi_ServerProcess+30> and ends at 0x80047a2 <WiFi_ServerProcess+34>.\n”
^done
-break-insert -f C:/DataRoot/Projects/bmp_windows_build/bmp_windows_build/bmp_windows_build/platforms/WifiF4/WiFi_Server.c:303
^done,bkpt={number=”7″,type=”breakpoint”,disp=”keep”,enabled=”y”,addr=”0x08004c16″,func=”WiFi_PutPacket”,file=”platforms/WifiF4/WiFi_Server.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\platforms\\WifiF4\\WiFi_Server.c”,line=”303″,thread-groups=[“i1″],times=”0″,original-location=”C:/DataRoot/Projects/bmp_windows_build/bmp_windows_build/bmp_windows_build/platforms/WifiF4/WiFi_Server.c:303″}
-break-after 7 1
^done
info symbol 0x8004c16
&”info symbol 0x8004c16\n”
~”WiFi_PutPacket + 54 in section .text\n”
^done
info line *0x8004c16
&”info line *0x8004c16\n”
~”Line 303 of \”platforms/WifiF4/WiFi_Server.c\” starts at address 0x8004c16 <WiFi_PutPacket+54> and ends at 0x8004c1c <WiFi_PutPacket+60>.\n”
^done
-data-evaluate-expression “&_estack”
^error,msg=”No symbol \”_estack\” in current context.”
-data-evaluate-expression “&__StackLimit”
^error,msg=”No symbol \”__StackLimit\” in current context.”
Cannot resolve the address of _estack. Skipping stack pointer validity check.
-exec-continue
^running
*running,thread-id=”all”
=breakpoint-modified,bkpt={number=”1″,type=”breakpoint”,disp=”keep”,enabled=”y”,addr=”0x08001e9a”,func=”main”,file=”main.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\main.c”,line=”54″,thread-groups=[“i1″],times=”1″,original-location=”main”}
~”\n”
~”Breakpoint 1, main (argc=0, argv=0xe000ed14) at main.c:54\n”
~”54\t\tplatform_init();\n”
*stopped,reason=”breakpoint-hit”,disp=”keep”,bkptno=”1″,frame={addr=”0x08001e9a”,func=”main”,args=[{name=”argc”,value=”0″},{name=”argv”,value=”0xe000ed14″}],file=”main.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\main.c”,line=”54″},thread-id=”1″,stopped-threads=”all”
-break-delete 1
^done
-exec-continue
^running
~”\nProgram”
~” received signal SIGTRAP, Trace/breakpoint trap.\n”
~”0x08017ca8 in do_AngelSWI (arg=0x20005d7c, reason=9) at /cygdrive/q/gnu/auto/newlib-2.4.0.20160923/newlib/libc/sys/arm/swi.h:78\n”
&”78\t/cygdrive/q/gnu/auto/newlib-2.4.0.20160923/newlib/libc/sys/arm/swi.h: No such file or directory.\n”
*stopped,reason=”signal-received”,signal-name=”SIGTRAP”,signal-meaning=”Trace/breakpoint trap”,frame={addr=”0x08017ca8″,func=”do_AngelSWI”,args=[{name=”arg”,value=”0x20005d7c”},{name=”reason”,value=”9″}],file=”/cygdrive/q/gnu/auto/newlib-2.4.0.20160923/newlib/libc/sys/arm/swi.h”,fullname=”/cygdrive/q/gnu/auto/newlib-2.4.0.20160923/newlib/libc/sys/arm/swi.h”,line=”78″},thread-id=”1″,stopped-threads=”all”
-data-read-memory-bytes 0x8017ca8 4
^done,memory=[{begin=”0x08017ca8″,offset=”0x00000000″,end=”0x08017cac”,contents=”abbe0446″}]
-data-list-register-names
^done,register-names=[“r0″,”r1″,”r2″,”r3″,”r4″,”r5″,”r6″,”r7″,”r8″,”r9″,”r10″,”r11″,”r12″,”sp”,”lr”,”pc”,””,””,””,””,””,””,””,””,””,”xpsr”,””,””,””,””,””,””,””,””,””,””,””,””,””,””,””,””,””,””,””,””,””,””,””,””,””,””,””,””,””,””,””,””,””,””,””,””,””,””,””,””,””,””,””,””,””,””,””,””,””,””,””,””,””,””,””,””,””,””,””,””,””,””,””,””,””,”msp”,”psp”,”primask”,”basepri”,”faultmask”,”control”,”fpscr”,”s0″,”s1″,”s2″,”s3″,”s4″,”s5″,”s6″,”s7″,”s8″,”s9″,”s10″,”s11″,”s12″,”s13″,”s14″,”s15″,”s16″,”s17″,”s18″,”s19″,”s20″,”s21″,”s22″,”s23″,”s24″,”s25″,”s26″,”s27″,”s28″,”s29″,”s30″,”s31″]
-data-list-register-values r10
^done,register-values=[{number=”0″,value=”0x00000009″},{number=”1″,value=”0x20005d7c”},{number=”2″,value=”0x00000001″},{number=”3″,value=”0x20001d44″},{number=”4″,value=”0x00000009″},{number=”5″,value=”0x20005d7c”},{number=”6″,value=”0x00000800″},{number=”7″,value=”0x0801a571″},{number=”8″,value=”0x00000000″},{number=”9″,value=”0x00000000″},{number=”10″,value=”0x200001d8″},{number=”11″,value=”0x2000052c”},{number=”12″,value=”0xffffffff”},{number=”13″,value=”0x20005d78″},{number=”14″,value=”0x08017c9d”},{number=”15″,value=”0x08017ca8″},{number=”25″,value=”0x21010000″},{number=”91″,value=”0x20005d78″},{number=”92″,value=”0x00000000″},{number=”93″,value=”0x00000000″},{number=”94″,value=”0x00000000″},{number=”95″,value=”0x00000000″},{number=”96″,value=”0x00000000″},{number=”97″,value=”0x00000000″},{number=”98″,value=”0x00000000″},{number=”99″,value=”0x00000000″},{number=”100″,value=”0x00000000″},{number=”101″,value=”0x00000000″},{number=”102″,value=”0x00000000″},{number=”103″,value=”0x00000000″},{number=”104″,value=”0x00000000″},{number=”105″,value=”0x00000000″},{number=”106″,value=”0x00000000″},{number=”107″,value=”0x00000000″},{number=”108″,value=”0x00000000″},{number=”109″,value=”0x00000000″},{number=”110″,value=”0x00000000″},{number=”111″,value=”0x00000000″},{number=”112″,value=”0x00000000″},{number=”113″,value=”0x00000000″},{number=”114″,value=”0x00000000″},{number=”115″,value=”0x00000000″},{number=”116″,value=”0x00000000″},{number=”117″,value=”0x00000000″},{number=”118″,value=”0x00000000″},{number=”119″,value=”0x00000000″},{number=”120″,value=”0x00000000″},{number=”121″,value=”0x00000000″},{number=”122″,value=”0x00000000″},{number=”123″,value=”0x00000000″},{number=”124″,value=”0x00000000″},{number=”125″,value=”0x00000000″},{number=”126″,value=”0x00000000″},{number=”127″,value=”0x00000000″},{number=”128″,value=”0x00000000″},{number=”129″,value=”0x00000000″}]
-interpreter-exec console flushregs
~”Register cache flushed.\n”
^done
-gdb-set $r0=0x1
^done
-gdb-set $pc=$pc+2
^done
-exec-continue
^running
~”\nProgram”
~”0x080179be in do_AngelSWI (arg=0x20005d1c, reason=5) at /cygdrive/q/gnu/auto/newlib-2.4.0.20160923/newlib/libc/sys/arm/swi.h:78\n”
~”78\tin /cygdrive/q/gnu/auto/newlib-2.4.0.20160923/newlib/libc/sys/arm/swi.h\n”
*stopped,reason=”signal-received”,signal-name=”SIGTRAP”,signal-meaning=”Trace/breakpoint trap”,frame={addr=”0x080179be”,func=”do_AngelSWI”,args=[{name=”arg”,value=”0x20005d1c”},{name=”reason”,value=”5″}],file=”/cygdrive/q/gnu/auto/newlib-2.4.0.20160923/newlib/libc/sys/arm/swi.h”,fullname=”/cygdrive/q/gnu/auto/newlib-2.4.0.20160923/newlib/libc/sys/arm/swi.h”,line=”78″},thread-id=”1″,stopped-threads=”all”
-data-read-memory-bytes 0x80179be 4
^done,memory=[{begin=”0x080179be”,offset=”0x00000000″,end=”0x080179c2″,contents=”abbe0446″}]
^done,register-values=[{number=”0″,value=”0x00000005″},{number=”1″,value=”0x20005d1c”},{number=”2″,value=”0x00000001″},{number=”3″,value=”0x20001d44″},{number=”4″,value=”0x00000005″},{number=”5″,value=”0x20005d1c”},{number=”6″,value=”0x00000001″},{number=”7″,value=”0x200021e0″},{number=”8″,value=”0x200001d8″},{number=”9″,value=”0x00000000″},{number=”10″,value=”0x20005e54″},{number=”11″,value=”0x00000001″},{number=”12″,value=”0xffffffff”},{number=”13″,value=”0x20005d18″},{number=”14″,value=”0x080179b1″},{number=”15″,value=”0x080179be”},{number=”25″,value=”0x210f0000″},{number=”91″,value=”0x20005d18″},{number=”92″,value=”0x00000000″},{number=”93″,value=”0x00000000″},{number=”94″,value=”0x00000000″},{number=”95″,value=”0x00000000″},{number=”96″,value=”0x00000004″},{number=”97″,value=”0x00000000″},{number=”98″,value=”0x00000000″},{number=”99″,value=”0x00000000″},{number=”100″,value=”0x00000000″},{number=”101″,value=”0x00000000″},{number=”102″,value=”0x00000000″},{number=”103″,value=”0x00000000″},{number=”104″,value=”0x00000000″},{number=”105″,value=”0x00000000″},{number=”106″,value=”0x00000000″},{number=”107″,value=”0x00000000″},{number=”108″,value=”0x00000000″},{number=”109″,value=”0x00000000″},{number=”110″,value=”0x00000000″},{number=”111″,value=”0x00000000″},{number=”112″,value=”0x00000000″},{number=”113″,value=”0x00000000″},{number=”114″,value=”0x00000000″},{number=”115″,value=”0x00000000″},{number=”116″,value=”0x00000000″},{number=”117″,value=”0x00000000″},{number=”118″,value=”0x00000000″},{number=”119″,value=”0x00000000″},{number=”120″,value=”0x00000000″},{number=”121″,value=”0x00000000″},{number=”122″,value=”0x00000000″},{number=”123″,value=”0x00000000″},{number=”124″,value=”0x00000000″},{number=”125″,value=”0x00000000″},{number=”126″,value=”0x00000000″},{number=”127″,value=”0x00000000″},{number=”128″,value=”0x00000000″},{number=”129″,value=”0x00000000″}]
-data-read-memory-bytes 0x20005d1c 12
^done,memory=[{begin=”0x20005d1c”,offset=”0x00000000″,end=”0x20005d28″,contents=”00000000e021002024000000″}]
-data-read-memory-bytes 0x200021e0 36
^done,memory=[{begin=”0x200021e0″,offset=”0x00000000″,end=”0x20002204″,contents=”434333313030206669726d776172652076657273696f6e20726561643a2031333130370a”}]
^done
-gdb-set $r0=0x0
-gdb-set $pc=$pc+2
^done
^done
-exec-continue
^running
~”\nProgram”
~”0x080179be in do_AngelSWI (arg=0x20005e9c, reason=5) at /cygdrive/q/gnu/auto/newlib-2.4.0.20160923/newlib/libc/sys/arm/swi.h:78\n”
*stopped,reason=”signal-received”,signal-name=”SIGTRAP”,signal-meaning=”Trace/breakpoint trap”,frame={addr=”0x080179be”,func=”do_AngelSWI”,args=[{name=”arg”,value=”0x20005e9c”},{name=”reason”,value=”5″}],file=”/cygdrive/q/gnu/auto/newlib-2.4.0.20160923/newlib/libc/sys/arm/swi.h”,fullname=”/cygdrive/q/gnu/auto/newlib-2.4.0.20160923/newlib/libc/sys/arm/swi.h”,line=”78″},thread-id=”1″,stopped-threads=”all”
^done,register-values=[{number=”0″,value=”0x00000005″},{number=”1″,value=”0x20005e9c”},{number=”2″,value=”0x00000001″},{number=”3″,value=”0x20001d44″},{number=”4″,value=”0x00000005″},{number=”5″,value=”0x20005e9c”},{number=”6″,value=”0x00000001″},{number=”7″,value=”0x200021e0″},{number=”8″,value=”0x200001d8″},{number=”9″,value=”0x00000000″},{number=”10″,value=”0x20005f2c”},{number=”11″,value=”0x00000001″},{number=”12″,value=”0xffffffff”},{number=”13″,value=”0x20005e98″},{number=”14″,value=”0x080179b1″},{number=”15″,value=”0x080179be”},{number=”25″,value=”0x210f0000″},{number=”91″,value=”0x20005e98″},{number=”92″,value=”0x00000000″},{number=”93″,value=”0x00000000″},{number=”94″,value=”0x00000000″},{number=”95″,value=”0x00000000″},{number=”96″,value=”0x00000004″},{number=”97″,value=”0x00000000″},{number=”98″,value=”0x00000000″},{number=”99″,value=”0x00000000″},{number=”100″,value=”0x00000000″},{number=”101″,value=”0x00000000″},{number=”102″,value=”0x00000000″},{number=”103″,value=”0x00000000″},{number=”104″,value=”0x00000000″},{number=”105″,value=”0x00000000″},{number=”106″,value=”0x00000000″},{number=”107″,value=”0x00000000″},{number=”108″,value=”0x00000000″},{number=”109″,value=”0x00000000″},{number=”110″,value=”0x00000000″},{number=”111″,value=”0x00000000″},{number=”112″,value=”0x00000000″},{number=”113″,value=”0x00000000″},{number=”114″,value=”0x00000000″},{number=”115″,value=”0x00000000″},{number=”116″,value=”0x00000000″},{number=”117″,value=”0x00000000″},{number=”118″,value=”0x00000000″},{number=”119″,value=”0x00000000″},{number=”120″,value=”0x00000000″},{number=”121″,value=”0x00000000″},{number=”122″,value=”0x00000000″},{number=”123″,value=”0x00000000″},{number=”124″,value=”0x00000000″},{number=”125″,value=”0x00000000″},{number=”126″,value=”0x00000000″},{number=”127″,value=”0x00000000″},{number=”128″,value=”0x00000000″},{number=”129″,value=”0x00000000″}]
-data-read-memory-bytes 0x20005e9c 12
^done,memory=[{begin=”0x20005e9c”,offset=”0x00000000″,end=”0x20005ea8″,contents=”00000000e021002017000000″}]
-data-read-memory-bytes 0x200021e0 23
^done,memory=[{begin=”0x200021e0″,offset=”0x00000000″,end=”0x200021f7″,contents=”43433331303020736574757020636f6d706c657465640a”}]
^done
-gdb-set $r0=0x0
^done
-gdb-set $pc=$pc+2
^done
-exec-continue
^running
~”\nProgram”
~”0x080179be in do_AngelSWI (arg=0x20005e0c, reason=5) at /cygdrive/q/gnu/auto/newlib-2.4.0.20160923/newlib/libc/sys/arm/swi.h:78\n”
*stopped,reason=”signal-received”,signal-name=”SIGTRAP”,signal-meaning=”Trace/breakpoint trap”,frame={addr=”0x080179be”,func=”do_AngelSWI”,args=[{name=”arg”,value=”0x20005e0c”},{name=”reason”,value=”5″}],file=”/cygdrive/q/gnu/auto/newlib-2.4.0.20160923/newlib/libc/sys/arm/swi.h”,fullname=”/cygdrive/q/gnu/auto/newlib-2.4.0.20160923/newlib/libc/sys/arm/swi.h”,line=”78″},thread-id=”1″,stopped-threads=”all”
^done,register-values=[{number=”0″,value=”0x00000005″},{number=”1″,value=”0x20005e0c”},{number=”2″,value=”0x00000001″},{number=”3″,value=”0x20001d44″},{number=”4″,value=”0x00000005″},{number=”5″,value=”0x20005e0c”},{number=”6″,value=”0x00000001″},{number=”7″,value=”0x200021e0″},{number=”8″,value=”0x200001d8″},{number=”9″,value=”0x00000000″},{number=”10″,value=”0x00000000″},{number=”11″,value=”0x00000000″},{number=”12″,value=”0xffffffff”},{number=”13″,value=”0x20005e08″},{number=”14″,value=”0x080179b1″},{number=”15″,value=”0x080179be”},{number=”25″,value=”0x210f0000″},{number=”91″,value=”0x20005e08″},{number=”92″,value=”0x00000000″},{number=”93″,value=”0x00000000″},{number=”94″,value=”0x00000000″},{number=”95″,value=”0x00000000″},{number=”96″,value=”0x00000004″},{number=”97″,value=”0x00000000″},{number=”98″,value=”0x00000000″},{number=”99″,value=”0x00000000″},{number=”100″,value=”0x00000000″},{number=”101″,value=”0x00000000″},{number=”102″,value=”0x00000000″},{number=”103″,value=”0x00000000″},{number=”104″,value=”0x00000000″},{number=”105″,value=”0x00000000″},{number=”106″,value=”0x00000000″},{number=”107″,value=”0x00000000″},{number=”108″,value=”0x00000000″},{number=”109″,value=”0x00000000″},{number=”110″,value=”0x00000000″},{number=”111″,value=”0x00000000″},{number=”112″,value=”0x00000000″},{number=”113″,value=”0x00000000″},{number=”114″,value=”0x00000000″},{number=”115″,value=”0x00000000″},{number=”116″,value=”0x00000000″},{number=”117″,value=”0x00000000″},{number=”118″,value=”0x00000000″},{number=”119″,value=”0x00000000″},{number=”120″,value=”0x00000000″},{number=”121″,value=”0x00000000″},{number=”122″,value=”0x00000000″},{number=”123″,value=”0x00000000″},{number=”124″,value=”0x00000000″},{number=”125″,value=”0x00000000″},{number=”126″,value=”0x00000000″},{number=”127″,value=”0x00000000″},{number=”128″,value=”0x00000000″},{number=”129″,value=”0x00000000″}]
-data-read-memory-bytes 0x20005e0c 12
^done,memory=[{begin=”0x20005e0c”,offset=”0x00000000″,end=”0x20005e18″,contents=”00000000e02100209b000000″}]
-data-read-memory-bytes 0x200021e0 155
^done,memory=[{begin=”0x200021e0″,offset=”0x00000000″,end=”0x2000227b”,contents=”576946695f4765745061636b6574203a2071537570706f727465643a6d756c746970726f636573732b3b7377627265616b2b3b6877627265616b2b3b7152656c6f63496e736e2b3b666f726b2d6576656e74732b3b76666f726b2d6576656e74732b3b657865632d6576656e74732b3b76436f6e74537570706f727465642b3b515468726561644576656e74732b3b6e6f2d726573756d65642b0a”}]
^done
-gdb-set $r0=0x0
^done
-gdb-set $pc=$pc+2
^done
-exec-continue
^running
=breakpoint-modified,bkpt={number=”7″,type=”breakpoint”,disp=”keep”,enabled=”y”,addr=”0x08004c16″,func=”WiFi_PutPacket”,file=”platforms/WifiF4/WiFi_Server.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\platforms\\WifiF4\\WiFi_Server.c”,line=”303″,thread-groups=[“i1″],times=”1″,original-location=”C:/DataRoot/Projects/bmp_windows_build/bmp_windows_build/bmp_windows_build/platforms/WifiF4/WiFi_Server.c:303″}
~”\nProgram”
~”0x080179be in do_AngelSWI (arg=0x200059b4, reason=5) at /cygdrive/q/gnu/auto/newlib-2.4.0.20160923/newlib/libc/sys/arm/swi.h:78\n”
*stopped,reason=”signal-received”,signal-name=”SIGTRAP”,signal-meaning=”Trace/breakpoint trap”,frame={addr=”0x080179be”,func=”do_AngelSWI”,args=[{name=”arg”,value=”0x200059b4″},{name=”reason”,value=”5″}],file=”/cygdrive/q/gnu/auto/newlib-2.4.0.20160923/newlib/libc/sys/arm/swi.h”,fullname=”/cygdrive/q/gnu/auto/newlib-2.4.0.20160923/newlib/libc/sys/arm/swi.h”,line=”78″},thread-id=”1″,stopped-threads=”all”
^done,register-values=[{number=”0″,value=”0x00000005″},{number=”1″,value=”0x200059b4″},{number=”2″,value=”0x00000001″},{number=”3″,value=”0x20001d44″},{number=”4″,value=”0x00000005″},{number=”5″,value=”0x200059b4″},{number=”6″,value=”0x00000001″},{number=”7″,value=”0x200021e0″},{number=”8″,value=”0x200001d8″},{number=”9″,value=”0x00000000″},{number=”10″,value=”0x00000000″},{number=”11″,value=”0x00000000″},{number=”12″,value=”0xffffffff”},{number=”13″,value=”0x200059b0″},{number=”14″,value=”0x080179b1″},{number=”15″,value=”0x080179be”},{number=”25″,value=”0x210d0000″},{number=”91″,value=”0x200059b0″},{number=”92″,value=”0x00000000″},{number=”93″,value=”0x00000000″},{number=”94″,value=”0x00000000″},{number=”95″,value=”0x00000000″},{number=”96″,value=”0x00000004″},{number=”97″,value=”0x00000000″},{number=”98″,value=”0x00000000″},{number=”99″,value=”0x00000000″},{number=”100″,value=”0x00000000″},{number=”101″,value=”0x00000000″},{number=”102″,value=”0x00000000″},{number=”103″,value=”0x00000000″},{number=”104″,value=”0x00000000″},{number=”105″,value=”0x00000000″},{number=”106″,value=”0x00000000″},{number=”107″,value=”0x00000000″},{number=”108″,value=”0x00000000″},{number=”109″,value=”0x00000000″},{number=”110″,value=”0x00000000″},{number=”111″,value=”0x00000000″},{number=”112″,value=”0x00000000″},{number=”113″,value=”0x00000000″},{number=”114″,value=”0x00000000″},{number=”115″,value=”0x00000000″},{number=”116″,value=”0x00000000″},{number=”117″,value=”0x00000000″},{number=”118″,value=”0x00000000″},{number=”119″,value=”0x00000000″},{number=”120″,value=”0x00000000″},{number=”121″,value=”0x00000000″},{number=”122″,value=”0x00000000″},{number=”123″,value=”0x00000000″},{number=”124″,value=”0x00000000″},{number=”125″,value=”0x00000000″},{number=”126″,value=”0x00000000″},{number=”127″,value=”0x00000000″},{number=”128″,value=”0x00000000″},{number=”129″,value=”0x00000000″}]
-data-read-memory-bytes 0x200059b4 12
^done,memory=[{begin=”0x200059b4″,offset=”0x00000000″,end=”0x200059c0″,contents=”00000000e02100204c000000″}]
-data-read-memory-bytes 0x200021e0 76
^done,memory=[{begin=”0x200021e0″,offset=”0x00000000″,end=”0x2000222c”,contents=”576946695f5075745061636b6574203a205061636b657453697a653d3430303b71586665723a6d656d6f72792d6d61703a726561642b3b71586665723a66656174757265733a726561642b0a”}]
^done
-gdb-set $r0=0x0
^done
-gdb-set $pc=$pc+2
^done
-exec-continue
^running
~”\nProgram”
^done,memory=[{begin=”0x20005e0c”,offset=”0x00000000″,end=”0x20005e18″,contents=”00000000e021002021000000″}]
-data-read-memory-bytes 0x200021e0 33
^done,memory=[{begin=”0x200021e0″,offset=”0x00000000″,end=”0x20002201″,contents=”576946695f4765745061636b6574203a20764d7573745265706c79456d7074790a”}]
^done
-gdb-set $r0=0x0
^done
-gdb-set $pc=$pc+2
^done
-exec-continue
^running
~”\nProgram”
~”0x080179be in do_AngelSWI (arg=0x20005ca4, reason=5) at /cygdrive/q/gnu/auto/newlib-2.4.0.20160923/newlib/libc/sys/arm/swi.h:78\n”
*stopped,reason=”signal-received”,signal-name=”SIGTRAP”,signal-meaning=”Trace/breakpoint trap”,frame={addr=”0x080179be”,func=”do_AngelSWI”,args=[{name=”arg”,value=”0x20005ca4″},{name=”reason”,value=”5″}],file=”/cygdrive/q/gnu/auto/newlib-2.4.0.20160923/newlib/libc/sys/arm/swi.h”,fullname=”/cygdrive/q/gnu/auto/newlib-2.4.0.20160923/newlib/libc/sys/arm/swi.h”,line=”78″},thread-id=”1″,stopped-threads=”all”
^done,register-values=[{number=”0″,value=”0x00000005″},{number=”1″,value=”0x20005ca4″},{number=”2″,value=”0x00000001″},{number=”3″,value=”0x20001d44″},{number=”4″,value=”0x00000005″},{number=”5″,value=”0x20005ca4″},{number=”6″,value=”0x00000001″},{number=”7″,value=”0x200021e0″},{number=”8″,value=”0x200001d8″},{number=”9″,value=”0x00000000″},{number=”10″,value=”0x20005ddc”},{number=”11″,value=”0x00000001″},{number=”12″,value=”0xffffffff”},{number=”13″,value=”0x20005ca0″},{number=”14″,value=”0x080179b1″},{number=”15″,value=”0x080179be”},{number=”25″,value=”0x210f0000″},{number=”91″,value=”0x20005ca0″},{number=”92″,value=”0x00000000″},{number=”93″,value=”0x00000000″},{number=”94″,value=”0x00000000″},{number=”95″,value=”0x00000000″},{number=”96″,value=”0x00000004″},{number=”97″,value=”0x00000000″},{number=”98″,value=”0x00000000″},{number=”99″,value=”0x00000000″},{number=”100″,value=”0x00000000″},{number=”101″,value=”0x00000000″},{number=”102″,value=”0x00000000″},{number=”103″,value=”0x00000000″},{number=”104″,value=”0x00000000″},{number=”105″,value=”0x00000000″},{number=”106″,value=”0x00000000″},{number=”107″,value=”0x00000000″},{number=”108″,value=”0x00000000″},{number=”109″,value=”0x00000000″},{number=”110″,value=”0x00000000″},{number=”111″,value=”0x00000000″},{number=”112″,value=”0x00000000″},{number=”113″,value=”0x00000000″},{number=”114″,value=”0x00000000″},{number=”115″,value=”0x00000000″},{number=”116″,value=”0x00000000″},{number=”117″,value=”0x00000000″},{number=”118″,value=”0x00000000″},{number=”119″,value=”0x00000000″},{number=”120″,value=”0x00000000″},{number=”121″,value=”0x00000000″},{number=”122″,value=”0x00000000″},{number=”123″,value=”0x00000000″},{number=”124″,value=”0x00000000″},{number=”125″,value=”0x00000000″},{number=”126″,value=”0x00000000″},{number=”127″,value=”0x00000000″},{number=”128″,value=”0x00000000″},{number=”129″,value=”0x00000000″}]
-data-read-memory-bytes 0x20005ca4 12
^done,memory=[{begin=”0x20005ca4″,offset=”0x00000000″,end=”0x20005cb0″,contents=”00000000e021002028000000″}]
-data-read-memory-bytes 0x200021e0 40
^done,memory=[{begin=”0x200021e0″,offset=”0x00000000″,end=”0x20002208″,contents=”2a2a2a20556e737570706f72746564207061636b65743a20764d7573745265706c79456d7074790a”}]
^done
-gdb-set $r0=0x0
^done
-gdb-set $pc=$pc+2
^done
-exec-continue
^running
=breakpoint-modified,bkpt={number=”7″,type=”breakpoint”,disp=”keep”,enabled=”y”,addr=”0x08004c16″,func=”WiFi_PutPacket”,file=”platforms/WifiF4/WiFi_Server.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\platforms\\WifiF4\\WiFi_Server.c”,line=”303″,thread-groups=[“i1″],times=”2″,original-location=”C:/DataRoot/Projects/bmp_windows_build/bmp_windows_build/bmp_windows_build/platforms/WifiF4/WiFi_Server.c:303″}
~”\n”
~”Breakpoint 7, WiFi_PutPacket (packet=0x801dd1c \”\”, size=0) at platforms/WifiF4/WiFi_Server.c:303\n”
~”303\t\t\tcsum = 0;\n”
*stopped,reason=”breakpoint-hit”,disp=”keep”,bkptno=”7″,frame={addr=”0x08004c16″,func=”WiFi_PutPacket”,args=[{name=”packet”,value=”0x801dd1c \”\””},{name=”size”,value=”0″}],file=”platforms/WifiF4/WiFi_Server.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\platforms\\WifiF4\\WiFi_Server.c”,line=”303″},thread-id=”1″,stopped-threads=”all”
-break-after 7 0
^done
-exec-continue
^running
~”\nProgram”
~”0x080179be in do_AngelSWI (arg=0x200059dc, reason=5) at /cygdrive/q/gnu/auto/newlib-2.4.0.20160923/newlib/libc/sys/arm/swi.h:78\n”
*stopped,reason=”signal-received”,signal-name=”SIGTRAP”,signal-meaning=”Trace/breakpoint trap”,frame={addr=”0x080179be”,func=”do_AngelSWI”,args=[{name=”arg”,value=”0x200059dc”},{name=”reason”,value=”5″}],file=”/cygdrive/q/gnu/auto/newlib-2.4.0.20160923/newlib/libc/sys/arm/swi.h”,fullname=”/cygdrive/q/gnu/auto/newlib-2.4.0.20160923/newlib/libc/sys/arm/swi.h”,line=”78″},thread-id=”1″,stopped-threads=”all”
^done,register-values=[{number=”0″,value=”0x00000005″},{number=”1″,value=”0x200059dc”},{number=”2″,value=”0x00000001″},{number=”3″,value=”0x20001d44″},{number=”4″,value=”0x00000005″},{number=”5″,value=”0x200059dc”},{number=”6″,value=”0x00000001″},{number=”7″,value=”0x200021e0″},{number=”8″,value=”0x200001d8″},{number=”9″,value=”0x00000000″},{number=”10″,value=”0x00000000″},{number=”11″,value=”0x00000000″},{number=”12″,value=”0xffffffff”},{number=”13″,value=”0x200059d8″},{number=”14″,value=”0x080179b1″},{number=”15″,value=”0x080179be”},{number=”25″,value=”0x210d0000″},{number=”91″,value=”0x200059d8″},{number=”92″,value=”0x00000000″},{number=”93″,value=”0x00000000″},{number=”94″,value=”0x00000000″},{number=”95″,value=”0x00000000″},{number=”96″,value=”0x00000004″},{number=”97″,value=”0x00000000″},{number=”98″,value=”0x00000000″},{number=”99″,value=”0x00000000″},{number=”100″,value=”0x00000000″},{number=”101″,value=”0x00000000″},{number=”102″,value=”0x00000000″},{number=”103″,value=”0x00000000″},{number=”104″,value=”0x00000000″},{number=”105″,value=”0x00000000″},{number=”106″,value=”0x00000000″},{number=”107″,value=”0x00000000″},{number=”108″,value=”0x00000000″},{number=”109″,value=”0x00000000″},{number=”110″,value=”0x00000000″},{number=”111″,value=”0x00000000″},{number=”112″,value=”0x00000000″},{number=”113″,value=”0x00000000″},{number=”114″,value=”0x00000000″},{number=”115″,value=”0x00000000″},{number=”116″,value=”0x00000000″},{number=”117″,value=”0x00000000″},{number=”118″,value=”0x00000000″},{number=”119″,value=”0x00000000″},{number=”120″,value=”0x00000000″},{number=”121″,value=”0x00000000″},{number=”122″,value=”0x00000000″},{number=”123″,value=”0x00000000″},{number=”124″,value=”0x00000000″},{number=”125″,value=”0x00000000″},{number=”126″,value=”0x00000000″},{number=”127″,value=”0x00000000″},{number=”128″,value=”0x00000000″},{number=”129″,value=”0x00000000″}]
-data-read-memory-bytes 0x200059dc 12
^done,memory=[{begin=”0x200059dc”,offset=”0x00000000″,end=”0x200059e8″,contents=”00000000e021002012000000″}]
-data-read-memory-bytes 0x200021e0 18
^done,memory=[{begin=”0x200021e0″,offset=”0x00000000″,end=”0x200021f2″,contents=”576946695f5075745061636b6574203a200a”}]
^done
-gdb-set $r0=0x0
^done
-gdb-set $pc=$pc+2
^done
-exec-continue
^running
=breakpoint-modified,bkpt={number=”7″,type=”breakpoint”,disp=”keep”,enabled=”y”,addr=”0x08004c16″,func=”WiFi_PutPacket”,file=”platforms/WifiF4/WiFi_Server.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\platforms\\WifiF4\\WiFi_Server.c”,line=”303″,thread-groups=[“i1″],times=”3″,original-location=”C:/DataRoot/Projects/bmp_windows_build/bmp_windows_build/bmp_windows_build/platforms/WifiF4/WiFi_Server.c:303″}
~”\n”
-break-after 7 0
^done
-exec-continue
^running
~”\nProgram”
^done
-gdb-set $r0=0x0
^done
-gdb-set $pc=$pc+2
^done
-exec-continue
^running
=breakpoint-modified,bkpt={number=”7″,type=”breakpoint”,disp=”keep”,enabled=”y”,addr=”0x08004c16″,func=”WiFi_PutPacket”,file=”platforms/WifiF4/WiFi_Server.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\platforms\\WifiF4\\WiFi_Server.c”,line=”303″,thread-groups=[“i1″],times=”4″,original-location=”C:/DataRoot/Projects/bmp_windows_build/bmp_windows_build/bmp_windows_build/platforms/WifiF4/WiFi_Server.c:303″}
~”\n”
-break-after 7 0
^done
-exec-continue
^running
~”\nProgram”
-gdb-set $r0=0x0
^done
^done
-gdb-set $pc=$pc+2
^done
-exec-continue
^running
=breakpoint-modified,bkpt={number=”7″,type=”breakpoint”,disp=”keep”,enabled=”y”,addr=”0x08004c16″,func=”WiFi_PutPacket”,file=”platforms/WifiF4/WiFi_Server.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\platforms\\WifiF4\\WiFi_Server.c”,line=”303″,thread-groups=[“i1″],times=”5″,original-location=”C:/DataRoot/Projects/bmp_windows_build/bmp_windows_build/bmp_windows_build/platforms/WifiF4/WiFi_Server.c:303″}
~”\n”
-break-after 7 0
^done
-exec-continue
^running
~”\nProgram”
^done
-gdb-set $r0=0x0
^done
-gdb-set $pc=$pc+2
^done
-exec-continue
^running
~”\nProgram”
^done,memory=[{begin=”0x20005e0c”,offset=”0x00000000″,end=”0x20005e18″,contents=”00000000e021002013000000″}]
-data-read-memory-bytes 0x200021e0 19
^done,memory=[{begin=”0x200021e0″,offset=”0x00000000″,end=”0x200021f3″,contents=”576946695f4765745061636b6574203a20210a”}]
^done
-gdb-set $r0=0x0
^done
-gdb-set $pc=$pc+2
^done
-exec-continue
^running
=breakpoint-modified,bkpt={number=”7″,type=”breakpoint”,disp=”keep”,enabled=”y”,addr=”0x08004c16″,func=”WiFi_PutPacket”,file=”platforms/WifiF4/WiFi_Server.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\platforms\\WifiF4\\WiFi_Server.c”,line=”303″,thread-groups=[“i1″],times=”6″,original-location=”C:/DataRoot/Projects/bmp_windows_build/bmp_windows_build/bmp_windows_build/platforms/WifiF4/WiFi_Server.c:303″}
~”\n”
~”Breakpoint 7, WiFi_PutPacket (packet=0x801dc84 \”OK\”, size=2) at platforms/WifiF4/WiFi_Server.c:303\n”
*stopped,reason=”breakpoint-hit”,disp=”keep”,bkptno=”7″,frame={addr=”0x08004c16″,func=”WiFi_PutPacket”,args=[{name=”packet”,value=”0x801dc84 \”OK\””},{name=”size”,value=”2″}],file=”platforms/WifiF4/WiFi_Server.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\platforms\\WifiF4\\WiFi_Server.c”,line=”303″},thread-id=”1″,stopped-threads=”all”
-break-after 7 0
^done
-exec-continue
^running
~”\nProgram”
~”0x080179be in do_AngelSWI (arg=0x20005a04, reason=5) at /cygdrive/q/gnu/auto/newlib-2.4.0.20160923/newlib/libc/sys/arm/swi.h:78\n”
*stopped,reason=”signal-received”,signal-name=”SIGTRAP”,signal-meaning=”Trace/breakpoint trap”,frame={addr=”0x080179be”,func=”do_AngelSWI”,args=[{name=”arg”,value=”0x20005a04″},{name=”reason”,value=”5″}],file=”/cygdrive/q/gnu/auto/newlib-2.4.0.20160923/newlib/libc/sys/arm/swi.h”,fullname=”/cygdrive/q/gnu/auto/newlib-2.4.0.20160923/newlib/libc/sys/arm/swi.h”,line=”78″},thread-id=”1″,stopped-threads=”all”
^done,register-values=[{number=”0″,value=”0x00000005″},{number=”1″,value=”0x20005a04″},{number=”2″,value=”0x00000001″},{number=”3″,value=”0x20001d44″},{number=”4″,value=”0x00000005″},{number=”5″,value=”0x20005a04″},{number=”6″,value=”0x00000001″},{number=”7″,value=”0x200021e0″},{number=”8″,value=”0x200001d8″},{number=”9″,value=”0x00000000″},{number=”10″,value=”0x00000000″},{number=”11″,value=”0x00000000″},{number=”12″,value=”0xffffffff”},{number=”13″,value=”0x20005a00″},{number=”14″,value=”0x080179b1″},{number=”15″,value=”0x080179be”},{number=”25″,value=”0x210d0000″},{number=”91″,value=”0x20005a00″},{number=”92″,value=”0x00000000″},{number=”93″,value=”0x00000000″},{number=”94″,value=”0x00000000″},{number=”95″,value=”0x00000000″},{number=”96″,value=”0x00000004″},{number=”97″,value=”0x00000000″},{number=”98″,value=”0x00000000″},{number=”99″,value=”0x00000000″},{number=”100″,value=”0x00000000″},{number=”101″,value=”0x00000000″},{number=”102″,value=”0x00000000″},{number=”103″,value=”0x00000000″},{number=”104″,value=”0x00000000″},{number=”105″,value=”0x00000000″},{number=”106″,value=”0x00000000″},{number=”107″,value=”0x00000000″},{number=”108″,value=”0x00000000″},{number=”109″,value=”0x00000000″},{number=”110″,value=”0x00000000″},{number=”111″,value=”0x00000000″},{number=”112″,value=”0x00000000″},{number=”113″,value=”0x00000000″},{number=”114″,value=”0x00000000″},{number=”115″,value=”0x00000000″},{number=”116″,value=”0x00000000″},{number=”117″,value=”0x00000000″},{number=”118″,value=”0x00000000″},{number=”119″,value=”0x00000000″},{number=”120″,value=”0x00000000″},{number=”121″,value=”0x00000000″},{number=”122″,value=”0x00000000″},{number=”123″,value=”0x00000000″},{number=”124″,value=”0x00000000″},{number=”125″,value=”0x00000000″},{number=”126″,value=”0x00000000″},{number=”127″,value=”0x00000000″},{number=”128″,value=”0x00000000″},{number=”129″,value=”0x00000000″}]
-data-read-memory-bytes 0x20005a04 12
^done,memory=[{begin=”0x20005a04″,offset=”0x00000000″,end=”0x20005a10″,contents=”00000000e021002014000000″}]
-data-read-memory-bytes 0x200021e0 20
^done,memory=[{begin=”0x200021e0″,offset=”0x00000000″,end=”0x200021f4″,contents=”576946695f5075745061636b6574203a204f4b0a”}]
^done
-gdb-set $r0=0x0
^done
-gdb-set $pc=$pc+2
^done
-exec-continue
^running
~”\nProgram”
^done
-gdb-set $r0=0x0
^done
-gdb-set $pc=$pc+2
^done
-exec-continue
^running
=breakpoint-modified,bkpt={number=”7″,type=”breakpoint”,disp=”keep”,enabled=”y”,addr=”0x08004c16″,func=”WiFi_PutPacket”,file=”platforms/WifiF4/WiFi_Server.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\platforms\\WifiF4\\WiFi_Server.c”,line=”303″,thread-groups=[“i1″],times=”7″,original-location=”C:/DataRoot/Projects/bmp_windows_build/bmp_windows_build/bmp_windows_build/platforms/WifiF4/WiFi_Server.c:303″}
~”\n”
-break-after 7 0
^done
-exec-continue
^running
~”\nProgram”
^done
-gdb-set $r0=0x0
^done
-gdb-set $pc=$pc+2
^done
-exec-continue
^running
~”\nProgram”
^done,memory=[{begin=”0x20005e0c”,offset=”0x00000000″,end=”0x20005e18″,contents=”00000000e021002015000000″}]
-data-read-memory-bytes 0x200021e0 21
^done,memory=[{begin=”0x200021e0″,offset=”0x00000000″,end=”0x200021f5″,contents=”576946695f4765745061636b6574203a204867300a”}]
^done
-gdb-set $r0=0x0
^done
-gdb-set $pc=$pc+2
^done
-exec-continue
^running
~”\nProgram”
~”0x080179be in do_AngelSWI (arg=0x20005ccc, reason=5) at /cygdrive/q/gnu/auto/newlib-2.4.0.20160923/newlib/libc/sys/arm/swi.h:78\n”
*stopped,reason=”signal-received”,signal-name=”SIGTRAP”,signal-meaning=”Trace/breakpoint trap”,frame={addr=”0x080179be”,func=”do_AngelSWI”,args=[{name=”arg”,value=”0x20005ccc”},{name=”reason”,value=”5″}],file=”/cygdrive/q/gnu/auto/newlib-2.4.0.20160923/newlib/libc/sys/arm/swi.h”,fullname=”/cygdrive/q/gnu/auto/newlib-2.4.0.20160923/newlib/libc/sys/arm/swi.h”,line=”78″},thread-id=”1″,stopped-threads=”all”
^done,register-values=[{number=”0″,value=”0x00000005″},{number=”1″,value=”0x20005ccc”},{number=”2″,value=”0x00000001″},{number=”3″,value=”0x20001d44″},{number=”4″,value=”0x00000005″},{number=”5″,value=”0x20005ccc”},{number=”6″,value=”0x00000001″},{number=”7″,value=”0x200021e0″},{number=”8″,value=”0x200001d8″},{number=”9″,value=”0x00000000″},{number=”10″,value=”0x20005e04″},{number=”11″,value=”0x00000001″},{number=”12″,value=”0xffffffff”},{number=”13″,value=”0x20005cc8″},{number=”14″,value=”0x080179b1″},{number=”15″,value=”0x080179be”},{number=”25″,value=”0x210f0000″},{number=”91″,value=”0x20005cc8″},{number=”92″,value=”0x00000000″},{number=”93″,value=”0x00000000″},{number=”94″,value=”0x00000000″},{number=”95″,value=”0x00000000″},{number=”96″,value=”0x00000004″},{number=”97″,value=”0x00000000″},{number=”98″,value=”0x00000000″},{number=”99″,value=”0x00000000″},{number=”100″,value=”0x00000000″},{number=”101″,value=”0x00000000″},{number=”102″,value=”0x00000000″},{number=”103″,value=”0x00000000″},{number=”104″,value=”0x00000000″},{number=”105″,value=”0x00000000″},{number=”106″,value=”0x00000000″},{number=”107″,value=”0x00000000″},{number=”108″,value=”0x00000000″},{number=”109″,value=”0x00000000″},{number=”110″,value=”0x00000000″},{number=”111″,value=”0x00000000″},{number=”112″,value=”0x00000000″},{number=”113″,value=”0x00000000″},{number=”114″,value=”0x00000000″},{number=”115″,value=”0x00000000″},{number=”116″,value=”0x00000000″},{number=”117″,value=”0x00000000″},{number=”118″,value=”0x00000000″},{number=”119″,value=”0x00000000″},{number=”120″,value=”0x00000000″},{number=”121″,value=”0x00000000″},{number=”122″,value=”0x00000000″},{number=”123″,value=”0x00000000″},{number=”124″,value=”0x00000000″},{number=”125″,value=”0x00000000″},{number=”126″,value=”0x00000000″},{number=”127″,value=”0x00000000″},{number=”128″,value=”0x00000000″},{number=”129″,value=”0x00000000″}]
-data-read-memory-bytes 0x20005ccc 12
^done,memory=[{begin=”0x20005ccc”,offset=”0x00000000″,end=”0x20005cd8″,contents=”00000000e02100201c000000″}]
-data-read-memory-bytes 0x200021e0 28
^done,memory=[{begin=”0x200021e0″,offset=”0x00000000″,end=”0x200021fc”,contents=”2a2a2a20556e737570706f72746564207061636b65743a204867300a”}]
^done
-gdb-set $r0=0x0
^done
-gdb-set $pc=$pc+2
^done
-exec-continue
^running
=breakpoint-modified,bkpt={number=”7″,type=”breakpoint”,disp=”keep”,enabled=”y”,addr=”0x08004c16″,func=”WiFi_PutPacket”,file=”platforms/WifiF4/WiFi_Server.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\platforms\\WifiF4\\WiFi_Server.c”,line=”303″,thread-groups=[“i1″],times=”8″,original-location=”C:/DataRoot/Projects/bmp_windows_build/bmp_windows_build/bmp_windows_build/platforms/WifiF4/WiFi_Server.c:303″}
~”\n”
-break-after 7 0
^done
-exec-continue
^running
~”\nProgram”
^done,memory=[{begin=”0x20005a04″,offset=”0x00000000″,end=”0x20005a10″,contents=”00000000e021002012000000″}]
^done
-gdb-set $r0=0x0
-gdb-set $pc=$pc+2
^done
^done
-exec-continue
^running
=breakpoint-modified,bkpt={number=”7″,type=”breakpoint”,disp=”keep”,enabled=”y”,addr=”0x08004c16″,func=”WiFi_PutPacket”,file=”platforms/WifiF4/WiFi_Server.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\platforms\\WifiF4\\WiFi_Server.c”,line=”303″,thread-groups=[“i1″],times=”9″,original-location=”C:/DataRoot/Projects/bmp_windows_build/bmp_windows_build/bmp_windows_build/platforms/WifiF4/WiFi_Server.c:303″}
~”\n”
-break-after 7 0
^done
-exec-continue
^running
~”\nProgram”
^done
-gdb-set $r0=0x0
^done
-gdb-set $pc=$pc+2
^done
-exec-continue
^running
=breakpoint-modified,bkpt={number=”7″,type=”breakpoint”,disp=”keep”,enabled=”y”,addr=”0x08004c16″,func=”WiFi_PutPacket”,file=”platforms/WifiF4/WiFi_Server.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\platforms\\WifiF4\\WiFi_Server.c”,line=”303″,thread-groups=[“i1″],times=”10″,original-location=”C:/DataRoot/Projects/bmp_windows_build/bmp_windows_build/bmp_windows_build/platforms/WifiF4/WiFi_Server.c:303″}
~”\n”
-break-after 7 0
^done
-exec-continue
^running
~”\nProgram”
^done
-gdb-set $r0=0x0
^done
-gdb-set $pc=$pc+2
^done
-exec-continue
^running
=breakpoint-modified,bkpt={number=”7″,type=”breakpoint”,disp=”keep”,enabled=”y”,addr=”0x08004c16″,func=”WiFi_PutPacket”,file=”platforms/WifiF4/WiFi_Server.c”,fullname=”C:\\DataRoot\\Projects\\bmp_windows_build\\bmp_windows_build\\bmp_windows_build\\platforms\\WifiF4\\WiFi_Server.c”,line=”303″,thread-groups=[“i1″],times=”11″,original-location=”C:/DataRoot/Projects/bmp_windows_build/bmp_windows_build/bmp_windows_build/platforms/WifiF4/WiFi_Server.c:303″}
~”\n”
-break-after 7 0
^done
-exec-continue
^running
~”\nProgram”
^done
-gdb-set $r0=0x0
^done
-gdb-set $pc=$pc+2
^done
-exec-continue
^running
*running,thread-id=”all”Sid
March 26, 2017 at 00:16 #10803support
Thanks for reporting this, looks like a bug on our side. Please try this build: http://sysprogs.com/files/tmp/VisualGDB-5.2.15.1444.msi
March 26, 2017 at 18:31 #10808sidprice
ParticipantThat works well, thanks,
Sid
