Break points not being set, VS 17, embedded C project
Sysprogs forums Forums VisualGDB Break points not being set, VS 17, embedded C project
  • #10862
    usernameasdfjk
    I’m having an issue where no break points are being set. Maybe you guys know what is going on. This is some of my output:
    C:\gcc\gcc-arm-none-eabi-5_4-2016q3-20160926-win32\bin\arm-none-eabi-gdb.exe –interpreter mi  path/to/…/file.hex
    All created breakpoints are pending. Setting a breakpoint at main()…
    Cannot resolve the address of _estack. Skipping stack pointer validity check.
    As you can see, the all the addresses of the break points are say <PENDING>:
    Num Type Disp Enb Address What
    2 breakpoint keep y <PENDING> path/to/file…/fileTest.c:7
    3 breakpoint keep y <PENDING> path/to/file…/main.c:1064
    4 breakpoint keep y <PENDING> path/to/file…/file.c:140
    5 breakpoint keep y <PENDING> path/to/file…/main.c:1063
    6 breakpoint keep y <PENDING> path/to/file…/main.c:1065
    7 breakpoint keep y <PENDING> path/to/file…/main.c:1066
    8 breakpoint keep y <PENDING> path/to/file…/main.c:1067
    9 breakpoint keep y <PENDING> main
    #10866
    Looks like you are trying to debug the .hex file instead of the ELF file (has no extension by default). Please double-check your debug settings; the ELF file contains the necessary symbol information and is vital for debugging.
    #10874
    usernameasdfjk
    Thank you very much for the quick and helpful response! You were indeed right.
