Break on std::exception
Sysprogs forums Forums VisualGDB Break on std::exception
  • This topic has 1 reply, 2 voices, and was last updated 12 years ago by ket.
  • #626
    svaha
    First of all I’d like to say this is an excellent tool.
    Is it possible to break on this line of code in VisualGDB?
    throw std::invalid_argument("Invalid!");
    In Visual Studio I would expect that I could do this from the Debug menu -> Exceptions -> check on std::exception. That doesn’t seem to work. Is there a GDB startup command I can use to replicate this feature?
    #2596
    ket
    We are considering adding support for Debug->Exceptions, currently that is however not supported.
    Use catchpoints to break on exception throws, you can find the relevant gdb documentation here: http://sourceware.org/gdb/onlinedocs/gdb/Set-Catchpoints.html
