boost intellisense issue?
Sysprogs forums Forums VisualGDB boost intellisense issue?
  • #10922
    thedixon
    My project uses boost. For some reason, clang intellisense finds a couple of problems there, here’s one example:
    Error [Clang IntelliSense] Error: ‘days_’ is a protected member of ‘boost::date_time::date<boost::gregorian::date, boost::gregorian::gregorian_calendar, boost::gregorian::date_duration>’ silverstreet c:\users\xxx\appdata\local\visualgdb\remotesourcecache\xxx\0008\include\boost\date_time\date.hpp 146
    Message [Clang IntelliSense] declared protected here silverstreet c:\users\xxx\appdata\local\visualgdb\remotesourcecache\xxx\0008\include\boost\date_time\date.hpp 196
    boost is 1.59. Nothing obvious comes to mind as to why would it not like it?
    Unless some
    #10928
    thedixon
    Update. This is not just boost. This particular type of template code produces the same complaint about protected member. Compiles just fine with gcc 5.4. Is that due to c++14 changes? If yes – any workaround short of waiting for the updated visual gdb with (hopefully) new clang?
    enum BookEnum
     f = 1,
     s = 2
    template <typename Derived>
     class CreatorHelper
     public:
     protected:
     template <BookEnum BOOK_TYPE>
     void* test();
     class FCreatorHelper
     public CreatorHelper<Derived>
     protected:
     Derived* derived() { return static_cast<Derived*>(this); }
     virtual void* foo();
    void* FCreatorHelper<Derived>::foo()
     return derived()->template test<f>();
    template <typename PipelineTraits>
     class RealCreator
     public FCreatorHelper<RealCreator<PipelineTraits> >
    class Traits
    void foo1() {
     RealCreator<Traits> h;
    Error [Clang IntelliSense] Error: ‘test’ is a protected member of ‘CreatorHelper<RealCreator<Traits> >’ Miscellaneous Files Header1.h 32
    Message [Clang IntelliSense] declared protected here Miscellaneous Files Header1.h 14
    Message [Clang IntelliSense] in instantiation of member function ‘FCreatorHelper<RealCreator<Traits> >::foo’ requested here Miscellaneous Files Header1.h 36
    • This reply was modified 9 years ago by thedixon.
    #10930
    thedixon
    Actually clang 3.4 also compiles it just fine. Are you having an even older version?
    #10937
    Thanks, this actually looks like a side effect of one of our fixes on top of the original Clang. Please try this build: http://sysprogs.com/files/tmp/VisualGDB-5.2.16.1462.msi
    #10949
    thedixon
    Confirmed fixed. Incidentally it seemed to fix all the crashes/slowness I was having with intellisense, it’s much faster and haven’t crashed yet. Very impressive work guys, especially considering it was Friday night.
    #10950
    thedixon
    Take it back on crashes – they are still happening. For some reason I’m having much faster responses here than in the email support, where I sent a couple of crash dumps to…
    #10954
    We usually respond faster to issues that do not require thorough investigation (like crash dumps). We will follow up on the crash dumps once we have more information about the cause.
