.bat build (Custom Build Server)
Sysprogs forums › Forums › VisualGDB › .bat build (Custom Build Server)
  • #36107
    Lonka
    I am trying to build an embedded project on another computer using the generated .bat file.
    In order to do so I have converted the project to a ‘Standalone Project’ and ticked the ‘Relative Paths’ in the setup.
    Unforturenately both startup_stm32wb55xx_cm4.gcc.rsp and custom_project.mkbin.rsp have a full file path to a project file in them, ex:
    “[…] -c C:/_Projects/Custom_Project/BSP/STM32WBxxxx/StartupFiles/startup_stm32wb55xx_cm4.c”
    instead of
    “[…] -c ./BSP/STM32WBxxxx/StartupFiles/startup_stm32wb55xx_cm4.c”
    Currently I am handling this using a post build script, but I would like to do without – how can I setup VisualGDB to avoid the last two full paths?
    Best Regards Nikolaj
    #36116
    You can try this build: VisualGDB-6.0.104.5230.msi. It uses relative paths for BSP sources, include directories and linker scripts, as long as they are within the project directory.
    #36181
    Lonka
    Great – that seems to work. Well done
