Automatic change between . and ->
Sysprogs forums Forums VisualGDB Automatic change between . and ->
  • #34743
    mattia
    I’m using VisualGDB version 5.6R9 build4807. I don’t know why, but the software doesn’t change automatically from . to -> when neeeded. Where should I check this?
    Mattia
    #34744
    We are not aware of any known problems that would cause this. A good starting point would be to try reproducing the problem on a clean project created from scratch. If you can reproduce it there, please share the repro steps that we could follow in order to reproduce the problem on our side.
    If not, please try comparing the broken project files against the working one – the difference is likely caused by some setting or something particular about the project structure.
