Attach to Linux exe not working
Sysprogs forums Forums VisualGDB Attach to Linux exe not working
  • #21227
    b.timofte
    I make a linux Executable with
    #include <iostream>
    using namespace std;
    int main(int argc, char *argv[])
    char sz[] = “Hello, World!”;    //Hover mouse over “sz” while debugging to see its contents
    cout << sz << endl;    //<================= Put a breakpoint here
    int a1 = 0;
    while(1)
    a1++;
    return 0;
    Then I click debug attach to project , i select VisualGDB and the IP adress , i select the linux process from the list and then i get the error :
    gdb –interpreter mi –args “/tmp/VisualGDB/c/VisualGdb/LinuxProject1/LinuxProject1/Debug/LinuxProject1″
    && export MANOPT=”–nh” && export LANG=”en_US.UTF-8″ && “gdb” –interpreter mi –args “/tmp/VisualGDB/c/VisualGdb/LinuxProject1/LinuxProject1/Debug/LinuxProject1″‘ as root on xxx.yyy
    • This topic was modified 8 years ago by b.timofte.
    #21231
    This doesn’t look like any error that should interfere with attaching. Please check the gdb log for other errors.
