Sysprogs forums › Forums › VisualGDB › Arduino STM32 error finding file
- This topic has 4 replies, 2 voices, and was last updated 6 years, 4 months ago by
December 5, 2019 at 10:03 #26723
MystikReasons
ParticipantI’m using a Nucleo STM32F411RE and I created an Arduino project with it.
Now my problem: I’ve copied a working code (on arduino uno) to the STM32 Arduino project and tried building it. It now can’t find the library “avr/sleep.h”.
The paths in the “Arduino Settings” windows are exactly the same.Why isn’t the STM32 Arduino project able to locate the file?
I’ve downloaded the STM32F4 generic series file while setting the project up.My VisualGDB version is: 5.5 Preview 2 build 3410
Loading cached code model from C:\Users\gwerderj\source\repos\STM32_MIOTY_LORA_LIKE_Dragino_SendString\VisualGDBCache\STM32_MIOTY_LORA_LIKE_Dragino_SendString-Debug-Generic_STM32F4_series\BuildCommandLines.txt…
Failed to parse code model from C:\Users\gwerderj\source\repos\STM32_MIOTY_LORA_LIKE_Dragino_SendString\VisualGDBCache\STM32_MIOTY_LORA_LIKE_Dragino_SendString-Debug-Generic_STM32F4_series\CodeModel.json:System.Exception: Arduino code model did not report any sketch sources
at vu2.p.b_2(IEnumerable`1 a)
Compiler output:
In file included from C:\Users\gwerderj\Documents\Arduino\Libraries\ts-unb-node-rfm95_LIKE_BOARD/at-protocol.h:18,
from C:\Users\gwerderj\Documents\Arduino\Libraries\ts-unb-node-rfm95_LIKE_BOARD/ts-unb-node.h:26,
from C:\Users\gwerderj\source\repos\STM32_MIOTY_LORA_LIKE_Dragino_SendString\sketches\STM32_MIOTY_LORA_LIKE_Dragino_SendString.ino:13:
C:\Users\gwerderj\Documents\Arduino\Libraries\ts-unb-node-rfm95_LIKE_BOARD/atmega328p.h:20:10: fatal error: avr/sleep.h: No such file or directory
#include <avr/sleep.h>
compilation terminated.
Checking if any source files need uploading…
Checking for file modifications…
Found changed files since last query (see C:\Users\gwerderj\source\repos\STM32_MIOTY_LORA_LIKE_Dragino_SendString\VisualGDBCache\STM32_MIOTY_LORA_LIKE_Dragino_SendString-Debug-Generic_STM32F4_series\BuildFileStats.txt.old vs C:\Users\gwerderj\source\repos\STM32_MIOTY_LORA_LIKE_Dragino_SendString\VisualGDBCache\STM32_MIOTY_LORA_LIKE_Dragino_SendString-Debug-Generic_STM32F4_series\BuildFileStats.txt.new). Rerunning code model query..
Saved the code model to C:\Users\gwerderj\source\repos\STM32_MIOTY_LORA_LIKE_Dragino_SendString\VisualGDBCache\STM32_MIOTY_LORA_LIKE_Dragino_SendString-Debug-Generic_STM32F4_series\BuildCommandLines.txt
Compiler output:
compilation terminated.========== Project Configuration Summary ==========
STM32_MIOTY_LORA_LIKE_Dragino_SendString configured in 00:11
========== Configuration: 1 Succeeded, 0 Failed ==========December 5, 2019 at 10:10 #26724MystikReasons
ParticipantAnd what is up with the Board part number?
Why isn’t the F411 included and how should I know which one to take?
You must be logged in to view attached files.December 5, 2019 at 10:13 #26726MystikReasons
ParticipantOkay I figured out the second problem with the board part number. I took the Generic STM32F4 series instead of the Nucleo-64 series.
But the “avr/sleep.h” file is still not being found.December 5, 2019 at 11:41 #26728MystikReasons
ParticipantI noticed that the STM32 Arduino project doesn’t have the same directory as the Arduino project.
See attached screenshots.
You must be logged in to view attached files.December 5, 2019 at 16:25 #26734support
KeymasterUnfortunately we are not able to guarantee that every possible combination of Arduino targets and libraries will work. Please consider posting on the Arduino forums for further support.
