Sysprogs forums › Forums › VisualGDB › Annoying Intellisense problems
- This topic has 3 replies, 2 voices, and was last updated 4 years, 2 months ago by
January 25, 2022 at 03:24 #32065
urosg
ParticipantI just created a new STM32CubeMX project via the build in wizard.
I opted for separate c/h files for each peripheral (using STM32H753ZI) and when I open “usart.c” file I get Intellisense red underlined keywords “GPIO_PIN_14” etc.
With error “[Clang intellisense] Error: use of undeclared identified ‘uint16_t'” – see attached screen snip.
Since the project compiles and runs without problems this is rather annoying.
I already tried deleting the .VisualGDB folder from the project after closing the project and then reloading it, does not help.
I am currently running the latest 5.6R3 (build 4531), what can I do to fix this?
You must be logged in to view attached files.January 25, 2022 at 09:41 #32072support
Another common cause of errors is updating to a new toolchain/BSP/SDK. Many of these components are maintained by device vendors or communities, and require minor adjustments to the project when switching to newer versions. If you have recently updated any of such components, please consider reverting back to the old version as described here. There is no need to downgrade VisualGDB itself, as it is updated separately from such components.
January 26, 2022 at 04:11 #32075urosg
ParticipantRecreating project from scratch seems to have helped (which was ok for this project as it was an old skeleton project), but it is hardly a solution IMHO as this means, that every time an update is available there is potential it will break.
Thank you for the reply, I will check other projects and see if the problem persists as it is problematic for Intellisense, no errors/warnings are present in build logs.
January 26, 2022 at 08:15 #32077support
Most likely, the problem was triggered by changing some setting in the old project, or hardcoding some parameter in it in a way that only worked with a specific version.
As you now have 2 nearly identical projects that work differently, you can always try comparing them file-by-file (and editing them to eliminate the differences one-by-one), to see what exact setting was causing this.
