Sysprogs forums › Forums › VisualGDB › Additional Memories Value Cannot be null: Path2
- This topic has 5 replies, 2 voices, and was last updated 3 years, 1 month ago by
January 31, 2023 at 11:18 #33773
psmig
ParticipantIn visual GDB I am trying to add external flash memory to an MIMXRT1062 chip. Regardless of the settings entered into additional memories, RAM or Flash, an error occurs.
VisualGDB version: 5.6.109.4777
—————— System.ArgumentNullException ——————
System.ArgumentNullException: Value cannot be null.
Parameter name: path2
at System.IO.Path.Combine(String path1, String path2)
at g4.o2(ge3 b, EmbeddedProfile c, IProjectEditContext a)
at g4.t_2(bn b, Object a)
at tl2.l(tc c, IProjectEditContext a, qk1 b)
at tl2.y1(tc b, qk1 a)
at VisualGDB.Common_GUI.Configuration_editors.ProjectPropertiesEditModel.g(Boolean b, h43 d, String a, Action c)
at VisualGDB.Common_GUI.WPF.ProjectPropertiesWindow3.OK_Click(Object sender, RoutedEventArgs e)
trace=[System.IO.Path.Combine:26, g4.o2:148, g4.t_2:524, tl2.l:98, tl2.y1:8, VisualGDB.Common_GUI.Configuration_editors.ProjectPropertiesEditModel.g:179, VisualGDB.Common_GUI.WPF.ProjectPropertiesWindow3.OK_Click:57]February 2, 2023 at 18:50 #33781support
The call stack you mentioned indicates that part of the project was not loaded correctly. We have tried reproducing this with a basic iMXRT1062 project, however it worked as expected. Most likely, the issue is triggered by some combination of settings you changed previously.
Please try reproducing the problem on a project created from scratch. If it reoccurs, please share the repro steps together with the screenshots per our problem reporting guidelines, and we will gladly investigate this further.
If the problem only happens on a specific project, it might be corrupt. Comparing the settings files against the working project should usually help track down the root cause.
February 3, 2023 at 10:08 #33792psmig
Participant- Create a new empty Embedded Project.
- Set up the project with MIMXRT1062XXX6A
- Go to solution explorer and right click the project
- Open VisualGDB Project Properties
- Go to additional memories and click add new external memory
- Click OK
I would expect this change to be accepted but instead I get the error mentioned above and attached below.
You must be logged in to view attached files.February 3, 2023 at 10:34 #33797support
Thanks for the detailed repro steps. It looks like you are using the ARMClang toolchain that uses Keil-specific scatter files instead of GNU linker scripts.
Unlike the GCC linker scripts that typically come from our BSPs and follow the same structure, the scatter files come from the Keil packs and can have an arbitrary structure, hence VisualGDB cannot edit them fully automatically.
We have updated VisualGDB on our side to show a warning on the External Memories page when using a non-GCC toolchain.
As a workaround, please consider creating a scatter file manually as shown on this page. You can configure the scatter file used by the project via VisualGDB Project Properties -> MSBuild Settings -> Linker Script or MSBuild Project Properties -> Linker -> Memory Layout -> Scatter file.
February 6, 2023 at 13:18 #33814psmig
ParticipantDo I need to use that workaround? Can Visual GDB still use the Keil and the scatter file without adding items to the additional memories dialogue?
February 6, 2023 at 14:29 #33815support
Sure, if you already have a scatter file, you can specify its location via either VisualGDB Project Properties -> MSBuild Settings -> Linker Script or MSBuild Project Properties -> Linker -> Memory Layout -> Scatter file, and VisualGDB will pass it to the Keil linker. The only limitation is that VisualGDB won’t be able to automatically edit it to add new memories (i.e. the Additional Memories page won’t work).
