Sysprogs forums › Forums › VisualGDB › Additional Memories
- This topic has 8 replies, 2 voices, and was last updated 6 years, 8 months ago by
Yuriy.
July 8, 2019 at 13:03 #25305
Yuriy
there are very useful tool – “Embedded Memory Explorer”, but it can show only two types of memory – “FLASH”, and “RAM”
Some MCU (like NXP i.MX RT1050) has three or more non-contiguous RAM regions.
We are trying to add these regions (ITC, DTC, OC SRAM) as “Additional Memories” in VisualGDB Project Properties, but got error (see attachements).
Now we found workaround to see all memory regions – modifiy RAMBase and RAMSize values in nxp_rt1050.xml
But this method is very inconvenient. Do you know another way to see all RAM regions in the Embedded Memory Explorer?
You must be logged in to view attached files.July 9, 2019 at 00:31 #25316support
The Additional Memories page should normally work, so most likely you are using some combination of settings that triggers a bug on our side. If you could reproduce this on a “LEDBlink” project created from scratch and send us the related files (ensure you clean the project before packing it), we should be able to release a hotfix for this promptly.
July 9, 2019 at 11:19 #25324Yuriy
ParticipantNo problem, I can show video (see attachments). Also you can download this video here: https://yadi.sk/i/NNkNbYOWUSVFLg
I created new project LEDBlink for one of supported MCU.
Used latest VisualGDB 5.4R10 (build 3225), and VisualGDB package manager has no updates.
I can provide any additional information, if needed. Thanks!
This reply was modified 6 years, 8 months ago by
Yuriy.
You must be logged in to view attached files.July 9, 2019 at 21:11 #25330support
KeymasterThanks for the detailed description. We have pinpointed the problem and fixed it in this build: VisualGDB-5.4.110.3228.msi
July 10, 2019 at 13:46 #25338Yuriy
ParticipantThanks, now “Additional memories” works better. In the example project “LEDBlink” now it’s possible to add new RAM.
In our project it still not work, but error more clear now:
VisualGDB version: 5.4.110.3228
------------------ System.ArgumentException ------------------
System.ArgumentException: The path is not of a legal form.
at System.IO.Path.LegacyNormalizePath(String path, Boolean fullCheck, Int32 maxPathLength, Boolean expandShortPaths)
at System.IO.Path.NormalizePath(String path, Boolean fullCheck, Int32 maxPathLength, Boolean expandShortPaths)
at System.IO.Path.GetFullPathInternal(String path)
at u72.x1(g8 b, EmbeddedProfile c, IProjectEditContext a)
at u72.f_4(de b, Object a)
at d7.q(zp b, IProjectEditContext c, kv1 a)
at d7.j(zp b, kv1 a)
at VisualGDB.Common_GUI.Configuration_editors.ProjectPropertiesEditModel.i(Boolean c, y3 d, String a, Action b)
at VisualGDB.Common_GUI.WPF.ProjectPropertiesWindow3.Apply_Click(Object sender, RoutedEventArgs e)This error appears for exactly the same memory parameters, as in example project.
Anyway, our issue was solved – now we can use “Embedded Memory explorer” for all RAM regions by modifying nxp_rt105.xml file
After modifying nxp_rt105.xml I can see additional memory in “Additional memories” dialog, but I can’t add new items and can’t modify existing memories (added manually to nxp_rt105.xml):
<ExtraMemories> <ExtraMemoryDefinition> <Name>RAM_ITC</Name> <Address>0</Address> <Size>131072</Size> <Type>RAM</Type> <ContainsText>true</ContainsText> <ContainsData>true</ContainsData> <ContainsBSS>true</ContainsBSS> <PreserveUnusedSymbols>false</PreserveUnusedSymbols> </ExtraMemoryDefinition> <ExtraMemoryDefinition> <Name>RAM_DTC</Name> <Address>536870912</Address> <Size>131072</Size> <Type>RAM</Type> <ContainsText>true</ContainsText> <ContainsData>true</ContainsData> <ContainsBSS>true</ContainsBSS> <PreserveUnusedSymbols>false</PreserveUnusedSymbols> </ExtraMemoryDefinition> </ExtraMemories>Attachments:
You must be logged in to view attached files.July 11, 2019 at 05:36 #25350support
KeymasterThis error looks like you are using some special characters or variables in the linker script path and VisualGDB fails to resolve them (it would need to resolve the linker path in order to insert the memory definitions in it). We have added more detailed error message for this error in the following build: VisualGDB-5.4.110.3230.msi
July 11, 2019 at 09:23 #25351Yuriy
ParticipantThanks, now it’s clear. Problem was in BSP. We use our BSP, and *.ld files are located in project directories, so we use relative path.
“Additional memories” can’t work with relative path. May be this video can help: https://yadi.sk/i/AxoUnZe4IcFQYQ
July 14, 2019 at 23:41 #25367support
KeymasterThanks for the update, we have reproduced the problem and fixed it in the following build: VisualGDB-5.4.111.3233.msi
July 15, 2019 at 07:46 #25369Yuriy
ParticipantNow everything works fine. Thanks for your support.
