Additional linker input relative path not working
Sysprogs forums Forums VisualGDB Additional linker input relative path not working
  • #24956
    ChangedDaily
    I am adding additional linker inputs to my project under the MSBuild settings->Additional Linker Inputs option. I can browse to the required file and select it:
    <span>$(BuildDir)\protocol\bluetooth\lib\EFR32MG12P\GCC\binapploader.o</span>
    but when I come to compile I get the error:
    <span>Error  /protocol/bluetooth/lib/EFR32MG12P/GCC/binapploader.o: No such file or directory…
    </span>
    This is a standalone project and I am using VGDB 5.4R3.
    How to fix this please?
    PS – If I change to use an absolute path it is OK. I have also checked the BuildDir is correct.
    • This topic was modified 6 years, 11 months ago by ChangedDaily.
    #24960
    Thanks for reporting this. It turns out, VisualGDB incorrectly substituted VisualGDB-level variables that are not available on the MSBuild level.
    Please try using the relative path (from the .vcxproj file’s directory) instead.
    You can also try this VisualGDB build that will not substitute unsupported variables when editing settings via VisualGDB Project Properties: VisualGDB-5.4.105.3146.msi
