Hello. Im pretty new in ESP32\arduino programming, but i have some experience in barebone mcu firmware design.
Usually, when i need to divide my project in separate source files, i just make “module name” folder and put *.c and *.h files in there. But when reading documentation of ESP-IDF i have found, what ESP-IDF suggest some different system, what called “components”. As per my understand, it is same as “C way” with *.c and *h files in they own directory, but also requests makefile and component description file to be inside.
Ok this is clear for me.
But for now, i work with arduino visualGDB project and seems there is no components folder, only “referenced libraries”. Also i can just create folder in solution explorer and include files in it.
So i have next questions:
1. In generic ESP-IDF VisualGDB project, can i just make folders and put my own source\header files in them? (like in other C oriented IDEs).
2. (if previous is false) In generic ESP-IDF VisualGDB project, all of the code not included in “main.c” file must be created as “IDF component”?
3. In Arduino ESP-IDF VisualGDB project, what is the correct way to extract usercode from main? Make arduino-like libraries?
Thank for your the attention.
This topic was modified 5 years, 9 months ago by
Badang.
