Add as link
Sysprogs forums Forums VisualGDB Add as link
  • #33443
    Sherlock
    Does Visual GDB not allow us to use the “Add as link” feature? That is add a link to a file in some other folder rather than having top copy, duplicate the file?
    #33444
    Please try using the Add->Existing Item command in Solution Explorer. It should do just what you described.
    #33445
    Sherlock
    I should have mentioned that, the problem is that when I do that the only buttons I see on the dialog is “Add” and “Cancel” I do not see the small arrow that usually appears. If I I try the same thing on some other non Visual GDB project I do see the small arrow. The dialog should show a button that looks like this:
    But I see no arrow, just a plain “Add” button.
    #33446
    This is by design. C++ and C# projects have different semantics, so this button is not needed on C++ projects.
    #33447
    Sherlock
    OK I see, so that’s not something I can do.
    Well my core question is then, how can I have two distinct projects, in different folders, be able to “see” source and headers in some other folder?
    Is there any way to adjust a project’s setting to tell it to include some source folder and some header folder, when compiling?
    I can see that the Visual Studio project settings offer an “Additional Include Directories”, is that the only way to do this? and can that also contain .c files, not only .h?
    I want to work on two distinct projects where each one must include some support headers and source files, I do not want to duplicate these as copies within each project’s folder so how can I do this?
    Thanks.
    #33448
    VisualGDB projects use the same semantics as the regular Win32 C++ projects. If you are new to C++ and are not familiar with header files and libraries, we would advise first creating the project layout you need using the regular Win32 C++ project type. Once that works the way you intend, feel free to let us know how you created it and we will point out the locations of equivalent VisualGDB settings.
    That said, the VisualGDB settings for C++ projects are designed to be as close as possible to the original Win32 C++ project properties, so once you get it working for the regular project type, finding the VisualGDB settings should be straight-forward.
    #33451
    Sherlock
    Hi, OK thanks, I did used to do a great deal of Win32 C development on Windows but that stopped around nine years ago so I am rusty.
    Anyway I did get what seeking to do, two projects each referring to to “libraries” – these are in an unrelated sub folder and the projects are referring to these source by relative paths and also have additional include paths specified at the MS project level, so that they can see the header for these libraries.
    The code is all being developed on Nucleo F446RE boards.
    You can see how I did this:
    • The libraries are here.
    • A transmitter project is here.
    • A receiver project is here
    (The receiver is at this point, more or less a clone of the transmitter, I’ve not really started working on that yet).
    This seems to be sufficient for what I wanted being able to share library code easily, but if you have any suggestions or ways to do this better, please do shout!
    • This reply was modified 3 years, 4 months ago by Sherlock.
    #33455
    If you you would like us to review your code and suggest the best layout for it, please contact our sales for a consulting quote.
    Otherwise, please make sure you reproduce the issue on a smaller “hello, world” setup involving the minimal amount of sources and libraries, and solve it successfully for a regular Win32 C++ project. If you then share the steps you needed to solve it for a Win32 project per our problem reporting guidelines (with full screenshots from scratch), we can point out the equivalent steps with VisualGDB.
