Shorthand view for string values in debug
Sysprogs forums › Forums › VisualGDB › Shorthand view for string values in debug
  • #31886
    viordash
    Hi!
    How can I set the normal appearance of string values when debugging. The current format, for example “abcd ‘0’ <repeat 100 times>”, is not friendly.
    Thanx
    • This topic was modified 4 years, 9 months ago by viordash.
    #31890
    This value comes directly from gdb. Please consider checking the gdb documentation for commands controlling it. You can add these commands to VisualGDB Project Properties -> Additional GDB Commands.
    #31894
    viordash
    Thank you, you have solved my problem.
    I have added this additional GDB commands to executing after selecting a target
    – set print repeats 200
    – set print elements 2000
    – set print sevenbit-strings off
