Get to know the compatibility of the CPU to the Chipset to the CPU upgrade for l
Sysprogs forums Forums Other tools & products Get to know the compatibility of the CPU to the Chipset to the CPU upgrade for l
This topic contains 3 replies, has 2 voices, and was last updated by  beautifulbuilding 1 month, 4 weeks ago.
  • #13187
    adamlevine
    The number of workers, “hyper-threading” technology and the ability to automatically overclock Turbo Boost
    Every day, we will find the words such as Dual Core, Core 2 Duo, Quad Core, … What are they? Mean? That’s the term for multipliers in a CPU chip support (usually the number of Physics).
    At present, the market has common CPU types:
    -Two CPU: AMD Phenom II X 2, Intel Dual Core, Core 2 Duo
    -CPU: AMD II X 4 four human Phenome, Quad Core, the Intel Core i3, Core i5, Core i7 -CPU: AMD Phenom II 6 X 6, Intel Core i7 Extreme Edition 980 x, …
    -CPU 8 Entertainment: Octa-Core processor and the CPU used in your server such as Intel Xeon E7 2820, AMD FX 8350, …
    -10: The CPU processor Core CPU used in the air, Deca server such as Intel Xeon E72850.
    To see and can be adjusted for the application you want, just run on a physical CPUat your disposal while running multiple CPUS then you can open the Task Manager interface and right-click the application/process would you like to see and do Edit, then select Set Affinity. However, this correction is not necessary if you do not understand about the operating system because it may cause an error when running some applications that need multiple processors.
    • This topic was modified 11 months, 1 week ago by  adamlevine.
    #20479
    adamlevine
    #20495
    adamlevine
    Nhiều người chơi xổ số thường chỉ quan tâm đến XSMN Minh Ngoc – SXMN – KQXSMN – KQSXMN – Ket qua xo so Mien Nam hom nay, làm thế nào để soi cầu lô dự đoán kết quả xổ số chính xác nhất, có cơ hội ăn tiền nhà cái càng nhiều càng tốt. Vì thế có khá nhiều thông tin thú vị về loại hình giải trí này mà họ chưa thực sự biết.
    Dưới đây là những sự thật khó tin về xổ số nổi bật nhất được công bố từ kết quả nghiên cứu của Ủy ban xổ số quốc gia Anh và tập đoàn Camelot vào năm 2015. Mời các bạn đón xem.
    Có đến 68% người trúng số tiếp tục hành trình tìm kiếm may mắn từ vé số
    Có nhiều người cho rằng, xổ số là một gánh nặng đối với người nghèo, nếu bỏ tiền đầu tư cho xổ số để hi vọng vớt vát được điều gì đó và tiếp tục thua, nghèo sẽ lại hoàn nghèo. Cũng có người cho rằng xổ số là thử thách thú vị cho những kẻ không biết sự lý thú của toán học. Cũng lại có người quan điểm xổ số là một gánh nặng của sự lạc quan.
    <div>[IMG]
    Trúng số làm thay đổi cuộc sống của nhiều người</div>
    Báo cáo nghiên cứu cho biết có hơn 2/3 số người trúng thưởng xổ số tiếp tục chơi xổ số dù cho giải thưởng họ đã nhận được là lớn hay bé. Điều này chứng tỏ kết quả xổ số không thực sự quan trọng. Có người tiếp tục chơi xổ số để giải trí, chơi cho vui, có người chơi xổ số để tiếp tục…làm giàu. Có người thì ở trong một trường hợp khác, họ nghiện xổ số.
    Tuy nhiên, có 1 sự thật là không ai thoát khỏi cám dỗ của việc có cơ hội trở thành người trúng độc đắc lần thứ 2.
    32% trong nhóm người trúng xổ số rơi vào tình trạng bị tăng cân
    Cái mà bạn đang nghĩ đến trong đầu chính là lí do tăng cân của 32% người này đấy. Sau khi trúng số, đặc biệt là những người trúng lớn, họ có xu hướng muốn hưởng thụ số tiền “trên trời rơi xuống” ấy.
    Sau khi trúng số, họ trở nên lười biếng hơn, không muốn làm việc, thường xuyên nghĩ đến việc sẽ ăn những món mà trước đây mình chưa từng được thử, nghĩ đến việc vứt bỏ công việc nhàm chán làm cho mất ngủ ngày này qua ngày khác để được ngủ bù.
    Còn số tiền họ đã trúng thì sao? Nó bị trôi dần vào những “hạng mục hưởng thụ” thay vì các “hạng mục đầu tư”
    Xem chi tiết hơn tại: https://flipboard.com/@Rongbachkim
    Hầu hết những người trúng xổ số độc đắc đều đi du lịch
    Nghiên cứu chỉ rõ có rất ít người không đi du lịch sau khi trúng số. Có khoảng 19% người trúng độc đắc xổ số quyết định đi du lịch ở nước ngoài, và đây cũng là lần đầu tiên họ đặt chân ra khỏi biên giới quốc gia.
    Có nhiều người chi tiền cho việc đi du lịch khá mạnh tay. Khoảng 7% người trúng độc đắc xổ số sắm cả chiếc xe RV với tiện nghi đầy đủ để đáp ứng cho chuyến du lịch hưởng thụ dài ngày. Có người còn chuyển luôn từ căn hộ chung cư sang ở nhà riêng, có người mua bất động sản ở nước ngoài.
    Trong số những người trúng số nằm trong danh sách nghiên cứu của Ủy ban xổ số quốc gia Anh, có khoảng 12% người trúng số chưa bao giờ ra nước ngoài, và họ cũng không có ý định đi ra nước ngoài.
    Có 1% người trúng xổ số đi phẫu thuật thẩm mỹ
    So với những con số bên trên, 1% này thực sự là quá ít ỏi. Đặc biệt lại là liên quan đến chuyện làm đẹp. Có nhiều người suy nghĩ rằng nếu họ trúng số, có tiền rơi trúng đầu, họ sẽ đi sửa lại khuôn mặt, cái chân, cái tay không đẹp của mình…Tuy nhiên, thực tế đã cho thấy, khi thực sự có tiền rơi trúng đầu, họ nghĩ đến chuyện khác.
    <div>[IMG]
    Chỉ có 1% số người trúng số đi phẫu thuật thẩm mỹ</div>
    Kết quả của sự thay đổi “chóng mặt” ấy là chỉ có 1% người trúng độc đắc xổ số quyết định dùng tiền xổ số đi phẫu thuật thẩm mỹ. Callie Rogers (16 tuổi – năm 2015) là một người trúng xổ số độc đắc trẻ nhất nước Anh vào thời điểm đó. Sau khi trúng gần 3 triệu đô la Mỹ, cô gái nhỏ đã quyết định chi tới hơn 18.000 đô la Mỹ để cải thiện kích thước…vòng 1.
    Tin buồn: 90% người trúng độc đắc xổ số…mất bạn bè
    Dừng ngay suy nghĩ về chết chóc nếu bạn đang nghĩ về chữ “mất” như vậy nhé. Có một sự thật thế này, nếu bạn trúng xổ số, bạn sẽ phải đối diện với việc bị nhiều người ghét. Vì sao? Vì họ ghen tỵ với bạn. Và chắc chắn bạn không thể cấm được người ta ghét bạn, ghen tỵ với bạn, bởi họ có lí do của riêng mình.
    Chỉ có 1 nửa số người trúng vé số cảm thấy cuộc sống của mình hạnh phúc hơn
    Theo một nghiên cứu trước đó của tập đoàn Camelot, có khoảng 55% người trúng số nói rằng họ cảm thấy hạnh phúc hơn. Khoảng 43% người lại trả lời rằng việc trúng số không ảnh hưởng đến trạng thái cuộc sống của họ. Và 2% còn lại than thở rằng họ gặp bất hạnh khi trúng số.
    Gần 50% người trúng độc đắc xổ số tiếp tục công việc thường ngày
    Có nghĩa là đến 1 nửa số người trúng số từ bỏ công việc cũ của bản thân, với nhiều lí do khác nhau, nhưng căn nguyên vẫn vì “tôi có tiền rồi, tôi sẽ có cuộc sống tốt hơn, công việc tốt hơn hiện tại”.
    Gần 50% người này tiếp tục với công việc thường ngày hoặc vì họ cảm thấy hài lòng với nó, hoặc vì họ suy nghĩ thấu đáo về hệ quả của việc họ nghỉ việc, hưởng thụ và đến 1 ngày nào đó họ sử dụng hết số tiền trúng số.
    Xem thêm: https://ok.ru/soicauxosovip3mienhomnay
    • This reply was modified 7 months, 3 weeks ago by  adamlevine.
    #21974
    beautifulbuilding
    <h2>Kinh ngạc trước vẻ đẹp không lẫn vào đâu của hai mẫu ôtô thật VinFast</h2>
    Những bức ảnh đầu tiên của chiếc SUV và sedan thuộc thương hiệu VinFast đang được lan truyền tốc độ chóng mặt trên mạng hiện nay. Đằng sau các ngỡ ngàng sẽ là những lời khẳng định về việc phải mua chính niềm tự hào vì suy cho cùng đất nước Việt Nam sắp có rất nhiều loại siêu phẩm ôtô không kém những thương hiệu ôtô từ châu Âu.
    <h3>Xe được xem là bước tiến dài so với concept</h3>
    Sau một năm tiến hành đặt chân vào lĩnh vực sản xuất ôtô từ thời điểm ngày 6/9, hãng VinFast đã công bố hàng loạt hình ảnh về hai sản phẩm SUV và sedan từ studio danh tiếng Pininfarina hoàn thiện. Nhiều chuyên gia đồng loạt đánh giá cao ngôn ngữ thiết kế sang trọng, bắt đúng xu hướng thế giới nhưng được thể hiện một tỷ lệ kích thước kinh điển, điều này giúp đảm bảo vẻ đẹp bền vững theo thời gian.
    Rõ ràng thương hiệu Pininfarina đã hực hiện rất tốt công việc hiện thực hóa các ý tưởng thiết kế sản phẩm thực mà vẫn đảm bảo được yếu tố sang chảnh và thời thượng của mẫu xe concept.
    *** Theo dõi video đánh giá xe Chevrolet Trailblazer tại Việt Nam: https://www.youtube.com/watch?v=oxAl8RD91Kc
    Theo phát biểu của ông Thành Lê, dựa vào hình ảnh vừa được hé lộ, chúng ta có thể nhận thấy xe VinFast trong thực tế đã thực hiện bước tiến dài so với phiên bản concept ban đầu. Trên mẫu sedan, những đường viền phức tạp nay đã được chuốt lại cực kỳ tinh tế, với rất nhiều đường gân chạy dọc theo thân xe, điều này mở rộng phóng khoáng, từ đó mang lại hình ảnh hài hòa cho tổng chiếc xe có một vẻ thanh lịch và kiêu hãnh. Xe SUV sở hữu những đường gân tạo mảng lồi, lõm điều này gợi ý về một khối động cơ mạnh mẽ phía bên dưới, điều này giúp mang tới cảm giác cứng cáp và thể thao đúng thị hiếu của đa số những người ưa chuộng dòng xe này.
    Trong thiết kế các sản phẩm ôtô phức tạp, cầu kì mà vẫn đảm bảo yếu tố thẩm mỹ thì không quá khó. Nhưng vấn đề thiết kế làm sao vừa đơn giản vừa hài hòa mà vẫn thật đẹp mới thực sự đẳng cấp.
    Theo chung quan điểm “Simply the Best” thì ông Nguyễn Thanh Hải vốn là chuyên gia hàng đầu trong ngành ôtô Việt Nam cho rằng, những mẫu concept luôn có khả năng thích mắt nhưng để chúng ta quyết định xuống tiền mua xe thì lại cần một sản phẩm ó độ bền vững hơn về yếu tố thiết kế.
    Ôtô được xem là một sản phẩm có giá trị lớn, thường đắt tiền và với nhiều người Việt Nam thì ôtô còn là tài sản lớn. Do đó, để khách hàng chọn mua thì họ cần có một sản phẩm đảm bảo sự chín chắn hơn là việc chọn lựa mẫu xe phá cách. Thật may mắn là xe VinFast vừa đảm bảo yếu tố thời thượng vừa sở hữu những điểm nhấn đầy tinh tế để có thể đảm bảo được độ bền dáng theo thời gian – trích lời ông Hải nhận định.
    Theo ông Hải thì cũng điểm qua những điểm cộng từ diện mạo thiết kế xe VinFast đó là sở hữu logo chữ V (đây vốn là biểu tượng cho Việt Nam) sở hữu màu bạc nổi bật và nằm trên lưới tản nhiệt được cách điệu sang chảnh và đẳng cấp. Thiết kế cụm đèn LED nhỏ (mắt híp) vô cùng thời thượng trải dài theo đuôi xe trông thật cá tính; hay vị trí khoảng cách phần ca lăng tới bánh trước rất ngắn nhằm giúp động cơ nằm phía sau bánh trước giúp chiếc xe sở hữu tính vận hành cao…
    *** Hướng dẫn thủ tục mua xe ôtô trả góp lãi suất thấp nhất: https://plus.google.com/+DailyXe/posts/B5iUox9EhU5
    <h3>Tự tin mang ô tô Việt chinh chiến tại thị trường quốc tế</h3>
    Hãng VinFast sẽ trở thành nhà sản xuất ôtô đầu tiên tại Việt Nam tham dự Top 5 triển lãm ôtô quy mô lớn nhất thế giới bằng sự kiện đưa hai chiếc xe Sedan và SUV vừa được công bố tới tham dự triển lãm Paris Motor Show vào thời điểm ngày 2/10 tới. Chính việc có xe thật để có thể tham dự triển lãm sau 1 năm gia nhập lĩnh vực ôtô chính là điều đã làm kinh ngạc giới chuyên môn.
    Khoảng Một năm trước, chữ VinFast chỉ xuất hiện trên băng rôn trước một bãi đất trống. Chỉ sau 365 ngày thì dòng chữ VinFast đó nay đã nằm sau đuôi của hai chiếc ôtô thật và nó chuẩn bị ra mắt thế giới. Chúng ta có thể thấy đó là một sự hiện hữu đầy kiêu hãnh. Có thể thấy đây không chỉ là bước đi ấn tượng của hàng xe VinFast mà điều này còn hứa hẹn là bước tiến rất dài của cả ngành công nghiệp sản xuất ôtô tại thị trường Việt Nam – trích lời ông Nguyễn Mạnh Thắng là Giám đốc Whatcar bình luận.
    *** Tham khảo Bang gia xe oto Chevrolet
    Theo Ông Thắng thì ông đánh giá cao tầm nhìn toàn cầu của tập đoàn Vingroup (làm chủ đầu tư VinFast) ngay thời điểm quyết định gia nhập sản xuất ôtô. Hiện nay, Việt Nam chỉ có khoảng 3 triệu ôtô cá nhân trong thị trường có khoảng 100 triệu dân, thực hiện so sánh với các nước trong khu vực như thị trường Thái Lan sở hữu 12 triệu xe trên tổng số dân gần 70 triệu. Có thể thấy rõ ràng tiềm năng để hạng xe VinFast xây dựng tại thị trường trong nước là rất lớn nhưng có thể thấy khát vọng của hãng xe Việt đã không bị giới hạn bởi vấn đề biên giới quốc gia.
    Từ ngày đầu, tập đoàn Vingroup đã nghĩ lớn và làm lớn cùng mục tiêu chinh phục thị trường quốc tế. Yếu tố tự tin này này tới từ việc Công ty này có chiến lược đầu tư đúng đắn. Chiếc ôtô mẫu của hãng hiện nằm trong dòng chảy thiết kế xe ôtô hiện đại không hề kém gì các mẫu ôtô châu Âu – trích lời ông Thắng nhận định.
You must be logged in to reply to this topic.
